a/c leaking h2o into interior
Discussion in 'Technical' started by mattmanb, Jul 31, 2006.
  1. mattmanb
    mattmanb Member
    Richmond, VA
    1977 2dr 302
    Hello guys and gals,
    My "new" 77 Mav is leaking water into the interior when I run the a/c. I looked at what was going on and saw that the "drain tube" is not ported to the outside. but just hanging down. I pulled a bit of the carpet back and do not see a factory drain area.
    My initial thought is to bore a hole through the firewall and shove the "drain tube" thru it.
    Have any of you folks had this issue and, what did you do?
    Thanks,
    Matt
    P.S. When I get to 50 posts I'll put some pics up (unless you can tell me a way around this...)
  2. Dave B
    Mine goes out the floor, just on the right side of the tranny tunnel, pretty close to the firewall.
  3. Mavaholic
    If it is a factory air system, there is a drain hole as Dave described. A lot of times the box drain gets clogged with crap. You can remove the hose and use a shop vac and wire to clean it out.
  4. mattmanb
    mattmanb Member
    Richmond, VA
    1977 2dr 302
    Mavaholic and Dave Boyer - Thanks for the info! Found the drain hole right where you'd said it would be. Now I can run the ac without a "modified" drain system (Mountain Dew bottle stuck into the drain hose!) The temps in Richmond have been miserable the last 3 weeks. A/C has been mandatory... Matt
