A/C Question
Discussion in 'Technical' started by kamadelaney, Jan 21, 2009.
  1. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    I had someone tell me that my AC was good but the reason it wasn't working is that I have a bad condensor, does this make sense?
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Doesn't make sense to me. A "good AC" has to put out cold air. Can't do that with a bad condenser. Maybe they meant it had a good compressor?
  3. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    I guess what I meant to say that the compressor is fine, but the condensor needs to be replaced. If that is all it takes I am going to buy one and put it in, but i am a Novice so i figured i would ask if it is possible that the condensor could be the problem.:oops:
  4. Jsarnold
    '72 Sprint
    OK, now you're beyond where I can help. I'll leave it to others to tell you about other issues such as other components, dryer and R134. I'll be listening 'cause I also have an empty AC system that I'll have to address some day.
    Jim
  5. 71gold
    ...if it has a hole in it...
    ...Frank...:cool:
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Yah if it holds a charge in the system but still does not work I would seriously see if your vacuum lines are working and your vents are opening properly. After that I would check to make sure the thermostatic valve is working correctly.
  7. 71gold
    was this...someone...at an A/C shop?
    ...:cool:...
  8. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    More of a general mechanic who tok an interest in the car while I was working on it Sunday.
  9. 71gold
    ...and does the...compressor clutch...click in when you turn the A/C on...
    ...:huh:...
  10. Craig Selvey
    The condensor going bad is pretty rare. Usually other parts fail first before the condesor goes bad.
  11. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    The compressor clutch does engage.
  12. 71gold
    is it the...stock compressor...?
  13. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    yes it is, the entire car is stock. It only has 12k miles on it and was stored in a garage since 1976.
  14. markso125
    markso125 Member
    Lewiston Ut
    does the defrost stay on all the time or do the dashboard vents ect come on when you move the selector lever up and down with the heat?
  15. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    The controls seem to work fine.
