A Fuse Problem.
Discussion in 'Technical' started by Bioinfomatic, Sep 11, 2007.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    It is rather simple my gauge lights don't illuminate anymore. But I did find the blown fuse, and there is no wording around the slot for this fuse or can I make out the amp for it. Can someone lend a hand here?
  2. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    Do a search of wiring diagram. Someone posted up the fuse block..I believe it is 4amps....
  3. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    So your probably sure its a 4amp fuse. I'll still see if I can find a fuse box diagram. (y)
  4. dtb147
    dtb147 Member
    Arbutus, MD
    My Chilton's manual confirms 4 amp.
  5. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Today I've installed the 4amp fuse but, It blew as soon as I installed it. Of course I've trace the wire to see if I could find a short but, all the wiring seems find and ok. Does anyone have any opinions on how to solve this problem? (My dad was murmuring something about checking the marker lights, because they are linked somehow, does something like this even sound remotely correct?)
  6. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I am not sure what is linked but it is simple to find out. Take the fuse out and see what does not work. Check those items. You might need a new or (used) insturnment panel it could be shorted out.
  7. scooper77515
    Someone on here has the wiring diagrams for each year, you could see what all is on that circuit.
