a little confused. throttle cable question
Discussion in 'Technical' started by ptpdub, Nov 14, 2009.
  1. ptpdub
    ptpdub Member
    canada Sk.
    do i need a different throttle cable for my 1975 mav? it had a 250 in it and it will have a 302 in it with a factory ford holly 4 barrel. i have searched this subject out on this forum and there are conflicting answers. any help would be appreciated.
  2. PaulS
    As far as I know you can use the longer 6 cable in the V8 but not the other way around.
  3. rthomas771
    ...just figure out a different mounting bracket. The V8 bracket mounts to the intake the 6 cyl bracket mounts to the block.
  4. ptpdub
    ptpdub Member
    canada Sk.
    thank you. i shall do so.
  5. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    There is a differant throttle cable for a 302. You can get one still at a parts store. You can not use a 250 throttle cable on a 302.
  6. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    My car had a 6cyl throttle cable on it until recently. It works, but I didn't like it. I had to put a bigger return spring on it than I would have liked, so the pedal wasn't exactly "crisp." The extra length caused it to be looped around too much. When it started to bind up I'd have to put an even stronger spring on it. When it bound up on the way to a cruise-in and nearly took me through a red light with my three year old in the back, I replaced it with a universal cable from the parts store. I don't remember if it was a Mr. Gasket or Spectre, but it works very well. I was able to put a much smaller spring on it, pedal has a very light feel now.
  7. 71gold
    used one on 3 different 302s...:thumbs2:
  8. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    I too used the 200/250 cable. I don't like it, it makes the pedal pretty stiff, no extra spring used. What auto supply are you getting stock 302 cables from?
  9. mike75mav
    mike75mav Member
    Bremerton, WA
    I know NAPA sells them.
  10. ptpdub
    ptpdub Member
    canada Sk.
    now this is why this forum is the absolute best one there is! thanks everyone.
  11. sierra grabber
    sierra grabber Certifiable
    northern nevada
    interesting, i couldnt get the right stock cable from napa, Kragen, auto krafters..... then i had to modify two of the aftermarket (spectre and lokar) ones to make one good one that doesnt come apart while driving down the freeway. must just be me?
  12. facelessnumber
    Memphis, TN
    '71 Grabber
    No, I couldn't find one either, and yes I did have to modify my aftermarket cable, probably for the same reason you did. I forgot about that. The pedal end of the cable snapped off way too easily when I was adjusting it for WOT. (I need the pedal to be at WOT just when it hits the floor, not before, because I have this "nerve condition" that causes me to forcefully stomp the bejebus out of it several times a day...:rolleyes:) Anyway, yeah, the end came off, so I took a short bolt, two fender washers, a lock washer and a nut, I drilled a hole through the side of the bolt just large enough for the cable end, and I tightened that sucker down. I'm kinda glad it came apart when it did, 'cause now I know it's solid.
