A minor issue
Discussion in 'Technical' started by PAINTANK, Nov 7, 2009.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Headlights on highbeam, Megadeth playing in the CD player(first album), Comet running 50mph, heat on high(dash vents) and fan on fastest setting...ALT light is dimly lit. OMG.
    Turn off the radio and it stays dimly lit, turn down the fan and it goes off. *sigh* not enough juice!
    I'm just sayin'. I wish I would have sprung for the 100amp alternator over the 65 amp one out of a 1979 Chevy van.
    Lessons learned my friends, lessons learned.
  2. Jeff S
    Jeff S Member
    NoVA
    none
    If the alternator wasnt producing enough power wouldnt the headlights had brightened/dimmed when you turned on/off the heater? Or did they?
    Thanks for sharing the lesson, I know itll help me (y)
  3. psrumors
    psrumors Member
    I bet it is more a wiring / ground issue over alternator amperage.
  4. PAINTANK
    1973 Comet 2 dr
    Maybe yall are right. I'll have to check it out. At least I know it's in the fan if it is a problem.
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Fan motors draw a lot of juice. Being 30+ years old, it's probably got a lot of wear on it ,too. For now, use the Hee Haw cure....."Don't do that!" [ run it on high] Probably be fine on low or medium.
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    did you replace the power line from the alt to the batt? the old one is probably a little coroded adding resistance and was made for our stock alt so it may be a little small...
  7. PAINTANK
    1973 Comet 2 dr
    New power line from the alt to the battery for sure. The alt I'm using is 63 amps from a Chevy van.
  8. Jeff S
    Jeff S Member
    NoVA
    none
    Well there's your problem.
    No need to thank me, its what I do. :tiphat:
    :p
