A New --------
Discussion in 'General Maverick/Comet' started by paulsonjosh, Aug 8, 2004.
  1. paulsonjosh
    paulsonjosh Member
    MINNESOTA
    MAVERICK
    IM SO STOKED I FOUND A NEW MOTOR FOR MY CAR IT IS A 300 i6 that was beefed to hell and saw the drag stip a couple of time tyhe guy how owns it is like 80 and is selling it for 2 houndred and the best part is it is suposed to have almost 5 houdred hourse power:bananaman :bananaman :bananaman :bananaman :D :rolleyes: (y)
  2. Mercurycruizers
    Venetia, PA
    Right on ! Good find.....
  3. Mavaholic
    Ahh, good find but you know that isnt going to bolt right in your car....right? Its totally different that the 250.
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    There was one at the roundup,, it was cool. I asked the owner if the 300 was hard to fit and install. He simply said YES, But in the end they will fit.
    Dan
  5. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    LOL, I think that was english. ;)
    500hp from a 300 six? You didn't mention whether the turbo or blower came with it.
  6. Stallion
    Stallion Member
    Elkridge Md
    '76 302 auto
    If that motor is for real, I'd look for an F150 to drop it in. You will regret a move into a mav. More headaches than you need. Unless you have like, a setup like those guys on "Monster Garage".......or something.
  7. paulsonjosh
    paulsonjosh Member
    MINNESOTA
    MAVERICK
    well i talked to the guy who ownes it finaly and found out the "real" stats on it
    300hourse
    200 ci block that was board
    and it has nevere accualy sewen the strip
    peopl exagerate too much
  8. Stallion
    Stallion Member
    Elkridge Md
    '76 302 auto
    if those are the correct, or close to real stats. Sounds like a real good buy. I didn't know you could get a 200 six to realize 300 ci. The 250 is the same block. So maybe it's just bored . Stroking that mill is new to me.
  9. HeLMeT 76x2
    HeLMeT 76x2 Two 76 Fords...!!!
    Vancouver, wa
    1 1976 ford 4-door maverick. 1 1976 ford econoline 100.
    just how hard are we talking about to get one in? what's going to need to be done? because i'm 3/4ths of the way thru putting a 302 in and i'm about to give up and try the i6 300..
    so yeah... what all has to be done to get the 300 to fit?
  10. Craig Selvey
    3/4 of the way to putting in a 302?? well.....take that amount times 2....and that wil put you about 3/4 of the way to putting in a 300-6.
    :D
  11. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    By putting a 300 in the Maverick, you are putting in a longer engine. To me, longer engines are harder to make fit than a wider engine.
  12. rayzorsharp
    If I'm not mistaken, it is also taller so you may have air cleaner clearance problems.
  13. Earl Branham
    Lugoff, SC
    If it is a 200cu in block, it will bolt right in, no problem. Sounds like a winner to me!!!
  14. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Sounds like a winner to me as well.
    Thats a HOT 6 banger!
  15. 71gold
    terry,
    i dissagree...i am taller (longer) than you and i fit in a mav. better than you being (wider). jmo.:smash: :biglaugh:
    p.s.josh,
    try here...http://fordsix.com/
