a pertronix question
Discussion in 'Technical' started by 72 maverick, Jul 15, 2007.
  1. 72 maverick
    72 maverick Member
    1972 four door 302
    okay i have a 72 302 all stock. I think i am going to install a pertronix module in it. With the module can i feed the coil full voltage?? I know the feed has a resistor to lower the voltage. So could i just run a key hot to the coil?? Which should give a slightly hotter spark?? And then what would be a good coil to upgrade to?? To give it a better spark? I assume a newer coil would have to have some affect?? So with a pertronix, can i feed the coil full voltage? And what would be a good coil to upgrade to??
    later!! chris
  2. PaulS
    Unless you are switching to a different coil higher voltage will not increase the power of the spark. It will however bun the coil up.
    I don't think the module is made to take the ful;l battery volts.
  3. 71gold
    "pertronix module"
    "pertronix flame thrower coil"
    they have to have ...full 12v...:yup:
    ...(y) ...
  4. bmcdaniel
    I'm running the Pertronix module with an MSD Blaster coil. In between them is a Mallory HyFire VI box that sends over 400 volts to the coil. :dancing:
  5. scooper77515
    I swapped to pertronix. Didn't change anything else. And as far as I know, I do not have a resistor anywhere...FWIW
  6. Earl Branham
    Lugoff, SC
    I run a Pertronix Ignitor ll, and an Acel SuperCoil. Works great, no resistor.
  7. Dave B
    Same here, no resistor.
  8. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Pertronix I does not need a full 12v, Pertronix II does. I ran the early version for 7 years through the resisted circuit with 8v. and it worked great.
    The techs at Pertronix confirmed the above for me.
  9. Earl Branham
    Lugoff, SC
    Good to know!
  10. 71gold
    i ran mine with 12v...:huh:
    ...:Handshake ...
  11. Dave B
    Mines a Pertronix 1 also. It's hooked directly to the coil, seemed to work fine when the engine was in the car.
  12. scooper77515
    I am pretty sure mine is a P-1, straight to the coil with 12 volts.
    He said that
    so I would guess that "not needing" doesn't prevent it from working well with 12v:huh:
  13. Max Power
    St. Paul, MN
    Correct, the first version can run with anywhere from 7v to 12v, you just don't need the 12v like with the II.
