About how much does a complete rebuild cost on a long block
Discussion in 'General Maverick/Comet' started by vvr210, May 11, 2012.
  1. vvr210
    vvr210 Member
    Vista,CA
    I was wondering if anyone here knew about how much should a complete rebuild cost me on a 250 straight 6...Im getting my block bored plateau honed decking the block grinding down crankshaft as well as balancing it..resurfacing the connecting rod bore..as well as the block main bearin bore..on the cylinder head they are going to resurface it port it put new exhaust seats and do a 3 angle valve job on all the seats.valves wil be resurfaced as well.the guy is also gonna weigh out all my pistons and make sure everything weighs the same...I am putting completely everything brand new..only thing that im reusing is crack and connecting rods...im putting new pistons with molly rings,brass freeze plugs..isky performance cam.new valves with new springs and retainers and keepers..new lifters new pushrods pretty much everything braaand new..to get all this done plus the block painted and assembled back together my estimate came up around $1700..and he said for another 300 bucks he would assemble my long block with completely everything and even fire it up to get compression numbers,etc..so around $2,000 bucks is what he told me..those this sounds like a decent price?:hmmm:
  2. Dave B
    I've had V8's done for that.
  3. vvr210
    vvr210 Member
    Vista,CA
    Allright im gonna see if i can work the guy down
  4. scooper77515
    Hmmm....:hmmm:
    My 5.0 +.040 cost me 200 freshly rebuilt. Yes, that is a rare occurrence, but my point is there are WAY better deals out there if you just look around. You can buy 5.0s from junk yards for $300 in running condition. You can run them into the ground, or put a couple hundred bucks into "freshening" them up, and still have more engine for less bucks than your guy is offering you.
  5. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    How many miles on those rods, might want new ones:huh:
  6. don graham
    I recently had 2 250's rebuilt.Bored +.020, new pistons, rings, cam, lifters, 3 angle valve job, painted and assembled for $1250 each.:)
    I don't think $1700 is out of the ballpark in California though. Seems they are higher out there.
  7. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I was thinking around 1200 to 1400. +1 on new Rods.:)
  8. vvr210
    vvr210 Member
    Vista,CA
    The rods only have 68,000 miles...the motor only had 68,000 miles but it had lousy lubrication service...but yea California seems to be a little more expensive :hmmm: I am going to see if I can drop the price to 1500 or 1700 around there..
  9. 71gold
    what do you plan on giving up to get there?
    on a 68XXX mile motor...just do a freshen up...:yup:
  10. 71gold
    ...here's a money saver...
    "new valves with new springs and retainers and keepers..new lifters new pushrods ."
  11. vvr210
    vvr210 Member
    Vista,CA
    My machinist was going to measure the valves to see if we could re use them but they looked real worn out... my spring arent squared enough and they are worn out as well.....im goin to need new lifters and push rods as well...Im going to talk to him about bringing the labor down...He said he would assemble it all togetehr for 300 bucks so if its more convinient for me I might just do it myself.:hmmm:
  12. Craig Selvey
    Do you know how? Do you have all the specialty tools to do that?
  13. 71gold
    if all this is going on in your motor...it has more than...68xxx miles on it...:yup:
  14. vvr210
    vvr210 Member
    Vista,CA
    i have all the tools at school.i took an engine rebuild class and I assembled and disassembled an engine so I pretty much know what to do..The engine has 68,000 miles but it hasnt ran since 2001..it didnt get oil changes often and it had lousy service
  15. 71gold
    this has nothing to do with...worn out... valves, springs, retainers and keepers, lifters, pushrods ...:huh:
    you should only need to replace...rod/main/cam bearings ...timming chain/gear if worn...new pistons and rings will be to the new bore size...:yup:
    "i took an engine rebuild class and I assembled and disassembled an engine ."
    you should already have known this...:yup:
