AC blows cold, but where does the blow go?
Discussion in 'Technical' started by CommieHook, Jul 26, 2012.
  1. CommieHook
    CommieHook Member
    Hot Springs, AR
    1974 Ford Maverick 4-door
    Hey guys, the air in Bessie blows pretty cold for a 38 year old I6 200ci Maverick. But my problem/question is this: When I have to get on the gas, the air "goes away", that is you can still hear it but it doesn't blow through the vents. I'm not sure where is goes, it's not the floor, maybe the defroster vent. Anyway, it has to be actuated by vacuum, so maybe I have a vacuum hose in the engine compartment in the wrong place?
    Ideas?
    Thanks,
    CommieHook
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Is your vacuum canister hooked up? Check valve working? When your engine loses vacuum the HVAC door(s) return to their non-vacuum state.
    The vacuum cannister isn't installed on mine and when the engine is under load I think outside air comes thru the dash vents. Yes, you should check all the vacuum line routing.
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    The defroster vent is the default path.. If you lose vac, it all goes there. One possible reason is a bad check valve or a leak in your vacuum reservoir (the coffee can on the passenger fender by the firewall).
    Sure this sits un-answered until I post a reply and then mine comes in last. :D
  4. Craig Selvey
    As stated....you don't lose your air. It is just redirected to the defrost mode. Same thing happens to my 4-door.
  5. mojo
    What abt a malfunctioning vac/servo motor?
  6. simple man
    simple man Member
    Bunnell,Florida
    I had this on mine. It will also cause a rough idle! The can looked perfect, but I did a vacuum test on it and sure enough, it leaked! I took it off and just hooked the two hoses together, so my ac does what yours does when I put a hard load on the engine. Since I don't do that very often, my ac works well so I've not bothered to replace the can. By the way, the bottom of the can had cracked around the edge. I'm going to guess metal fatigue from pressurizing to evacuating constantly! :)
  7. CommieHook
    CommieHook Member
    Hot Springs, AR
    Um, I don't have the "coffee" can under the hood, but I do know what you're talking about....is this a problem?
    CommieHook
  8. Grabber5.0
    Kansas City, MO
    71 Grabber
    Without the reservoir, it would do exactly what you described, as it doesn't have a reserve of vacuum for those low-vacuum situations. I ordered a generic plastic one from Rockauto rather than finding one from a junkyard. It was about $10.
  9. Jsarnold
    '72 Sprint
    No problem if you don't mind the occasional changes to air flow.
  10. darren
