Acceleration!!!
Discussion in 'Technical' started by Earl Branham, Feb 27, 2004.
  1. Earl Branham
    Lugoff, SC
    A friend of mine mailed this to me today...enjoy!!!
    Subject: The definition of acceleration.
    * One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
    than the first 4 rows at the Daytona 500.
    * Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro
    methane per second; a fully loaded 747 consumes jet fuel at the same rate
    with 25% less energy being produced.
    * A stock Dodge Hemi V8 engine cannot produce enough power to drive the
    dragster supercharger.
    * With 3000 CFM of air being rammed in by the supercharger on overdrive, the
    fuel mixture is compressed into a near-solid form before ignition. Cylinders
    run on the verge of hydraulic lock at full throttle.
    * At the stoichiometric (stoichiometry: methodology and technology by which
    quantities of reactants and products in chemical reactions are determined)
    1.7:1 air/fuel mixture for nitro methane the flame front temperature
    measures 7050 degrees F.
    * Nitro methane burns yellow. The spectacular white flame seen above the
    stacks at night is raw burning hydrogen, dissociated from atmospheric water
    vapor by the searing exhaust gases.
    * Dual magnetos supply 44 amps to each spark plug. This is the output of an
    arc welder in each cylinder.
    * Spark plug electrodes are totally consumed during a pass. After 1/2 way,
    the engine is dieseling from compression plus the glow of exhaust valves at
    1400 degrees F. The engine can only be shut down by cutting the fuel flow.
    * If spark momentarily fails early in the run, unburned nitro builds up in
    the affected cylinders and then explodes with sufficient force to blow
    cylinder heads off the block in pieces or split the block in half.
    * In order to exceed 300 mph in 4.5 seconds dragsters must accelerate an
    average of over 4G's. In order to reach 200 mph well before half-track, the
    launch acceleration approaches 8G's.
    * Dragsters reach over 300 miles per hour before you have completed reading
    this sentence.
    * Top Fuel Engines turn approximately 540 revolutions from light to light!
    * Including the burnout the engine must only survive 900 revolutions under
    load.
    * The redline is actually quite high at 9500rpm.
    * The Bottom Line; Assuming all the equipment is paid off, the crew worked
    for free, and for once NOTHING BLOWS UP, each run costs an estimated
    $1,000.00 per second.
    The current Top Fuel dragster elapsed time record is 4.441 seconds for the
    quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00
    mph. (533 km/h) as measured over the last 66' of the run (09/28/03 Doug
    Kalitta).
    Putting all of this into perspective: You are driving the average $140,000
    Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a
    Top Fuel dragster is staged and ready to launch down a quarter mile strip as
    you pass. You have the advantage of a flying start. You run the 'Vette hard
    up through the gears and blast across the starting line and past the
    dragster at an honest 200 mph. The 'tree' goes green for both of you at that
    moment. The dragster launches and starts after you. You keep your foot down
    hard, but you hear an incredibly brutal whine that sears your eardrums and
    within 3 seconds the dragster catches and passes you. He beats you to the
    finish line, a quarter mile away from where you just passed him. Think about
    it, from a standing start, the dragster had spotted you 200 mph and not only
    caught, but nearly blasted you off the road when he passed you within a mere
    1320 foot long race course.
    That folks, is acceleration
    Earl
    Russell likes this.
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
  3. Mavaholic
    Geeeeeeeezzzzzzzzzz. Kinda makes my 12 second car seem like a tinker toy.
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    not to mention...
    the upswept headers on a top feuler generate somewhere in the neighborhood of 6000 lbs of downforce.
    There is nothing more incredible than a top feul dragster in my opinion.
  5. don graham
    i'll be there next week as i have tickets for fri/sat/sun for the csk nationals at firebird raceway in phoenix.:D :D :D
  6. riporter
    riporter Member
    Charleston S.C.
    Good stuff Earl...Thanks...think I'll waddle over to the shop and tinker with my little 300 hp 302 for awhile:)
  7. Hanible
    Hanible Member
    outa my mind in Shelby Nebraska
    69.5 2 door Maverick 170 I6
    i wonder how my little six cylender would run on nitromethane??? hmmmmmmmmm
  8. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    It has only been fairly recent that a dyno has been built to even measure the horsepower, if I'm not mistaken.
  9. Earl Branham
    Lugoff, SC
    Max; the last figures I saw was that a Top Fuel dragster was making 8,000hp.
    Earl
  10. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
    sweeeet...... 8000hp wow..... never realized they had that much
  11. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
