Accell Coil crapped out
Discussion in 'Technical' started by Hairy W Bush, Feb 4, 2016.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    This is the 2nd Accell coil on this car that is leaking oil. This one does not have many miles on it at all. I am looking for a different brand now. An MSD Streetfire coil is around the same price so I'm interested in that. However, I came across this: http://www.msdignition.com/Products/Coils/Accessories/8214_-_Coil_Ballast_Resistor_0_8_ohm.aspx
    it says with a Blaster coil, but I'm still wondering. Plus, my car still has the ballast resistor wire connected so I'm wondering if it's still necessary.
  2. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    ive taken the resistor out on all my vehicles.
  3. 71gold
    is this for a race app. or srtreet car?
    I've had several of the "high Performance" coils go out (no ballast resistor). the last one was on a road trip to Fl.with my 347 and I got a stock coil from NAPA and it was all good from then on. it came blue and I never painted it.
    :drive:...:chirp:
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I too have just replaced a leaking Accel coil that was less than 2 years old. I replaced it with a Taylor and do not use an external ballast, although I believe there is a factory resistor wire in the harness.
  5. Hairy W Bush
    Hairy W Bush Member
    Georgia
    beautiful engine. this is just a street car, but you know how we are sometimes. I want something that will work with both my points and HEI in the future. I called MSD to be sure and they said to use it with the streetfire coil. The Accell has more resistance already.
    you too? ridiculous. yes there is. i still can't wrap my head around this having both though so I don't know what to do short of buying another accell which i don't want to do. What's your taylor part # and are you still running points?
    I'm looking at a Mallory 29217 and a pertronix 40011
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I'll bet you don't miss those towers!
  7. jasonwthompson
    Carrollton TX
    I picked it up from Summit. The part number is 718205. I have the factory electronic ignition from 1975.
  8. 71gold
    I remove the covers and can remove/replace plugs and headers...:yup:
