Accessories on Maverick
Discussion in 'General Maverick/Comet' started by Steve H., Mar 12, 2005.
  1. Steve H.
    Steve H. Member
    Lake Havasu City, Az.
    1970, 1972, 1974 Maverick
    Engine accessories on Maverick
    These are pictures of the CSI waterpump, electric fan and miniature single wire alternator. The installation turned out clean, plus nothing sucking power from the motor. I built the fan shroud, and the brackets for the alternator.
  2. Steve H.
    Steve H. Member
    Another picture of water pump
    This is another shot of the water pump. Definetley makes things run cool.
  3. Steve H.
    Steve H. Member
    Engine compartment
    I will submit another photo of the engine compartment when I get the wires bundled up and routed. If any one is interested I might be able to supply them with a fan shroud for an electric fan, and the fan also. They are the same fans used by the desert racers on the trophy trucks. In fact Robbie Gordon uses this same fan assembly. I cut mine out on my CNC plasma cutter. I had an electric Moroso style water pump before the CSI one. The fan was close to the water pump pulley, but with button head bolts holding the water pump pulley on, there was plenty of clearance. Even more now with the new pump.
