Accidentally put 1/2 qt ATF+4 in. Am I OK?
Discussion in 'General Maverick/Comet' started by scooper77515, Oct 19, 2012.
  1. scooper77515
    Just topping off my C4 which I usually use Type F in, and after I dumped in half a quart, I noticed I had grabbed the wrong bottle and put in ATF+4.
    Will it hurt?
    Can I drive 100 miles (round trip) to car show in morning?
  2. car-nut
    car-nut Glenn
    conn.
    I am not sure, but I can't imagine a half quart would hurt too much?
  3. Dave B
    Do you ever read the label?
  4. scooper77515
    I was rushing to get the car ready for an early drive early tomorrow morning, and grabbed the wrong bottle. I have three different kinds of ATF in my cabinets...:hmmm:
    Trust me, If someone knowledgeable pipes in and says it will destroy my transmission, I will be VERY embarrassed to show up without my car tomorrow morning. I don't have time to swap it out, either.
    For what it is worth, the Type F is pretty new, and has less than 300 miles on it. I am only topping it off to replace the stuff that has leaked onto the garage floor over the past summer.
  5. junrai
    junrai Member
    rancho cordova ca
    I was told from my trans shop to use dextron 4 or typr f they said the mercron had a higher burn point and wouldnt hurt anything so I dont think youll hurt anything
  6. simple man
    simple man Member
    Bunnell,Florida
    A pint shouldn't hurt it a bit! It holds 8 or 9 quarts. :thumbs2:
  7. Joe Dirt
    Wont hurt at all half a quart in 10+qts isnt a issue
  8. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    I only use mercron in my C4. My trans guy says it works better than the type F
  9. scooper77515
    Alright! I am on the road to the car show this morning with NO WORRIES!!!
    I figured there was at least 8 qts in there, and a half qt of the wrong stuff shouldn't make a difference.
    But you all know how much I worry...:rolleyes:
  10. darren
    that only applies if its a new build with new clutches and bands ron. just making that clear for the guys running type f.:)
  11. Joe Dirt
    X2 the only fluid i would swap to if it isnt is hyguard
  12. mav1970
    I was told years ago that the difference in fluids was that either Type F or Dextron had an extra ingrediant to take care of the type of o-rings in either the GM or Ford trans but I don't remenber which way it went but as others have already said - that small amount should not be a problem :yup:
  13. starsky74
    starsky74 Technician
    Hackberry Louisiana
    What car show?
  14. scooper77515
  15. starsky74
    Hackberry Louisiana
    Shoot!!! I need to be paying more attention! I thought you might be talking about the eleventh street cruise (cool autumn nites) in Beaumont
