Aeromotive phantom/tanks inc photo request.
Discussion in 'General Maverick/Comet' started by 7D2 Grabber, Apr 6, 2016.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I ordered my spectra tank and aeromotive phantom kit. Did you guys use the vent hole area to install the in tank pump? Is there sufficient room for the fuel lines? Tanks inc sells a recess which is an alternative to the vent hole. How much room did you guys have from the trunk floor to the lines. Pictures are welcomed. Thanks guys
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Look at my showcase post. (Even though you got me with the April fools :eek:)
    Micah
  3. 7D2 Grabber
    7D2 Grabber Member
    Ha. How much room do you have for the lines?
  4. 71Mavrk
    71Mavrk Member
    Nevada
    Not much but it works.
    The weld in access plate is nice. I did not learn about it until after. Just added expense.
    Micah
  5. tody
    tody Member
    cologne, germany
    please make sure to take lots of pictures, i'm tending towards this solution as well!
  6. 55crownvic
    55crownvic Member
    colorado springs
    Installed a Tanks.Inc pump in the tank of my 70 Mav, worked well and wasnt too difficult. Ran steel brake lines to the engine comp, then flex lines to the 5.0 injector lines IMG_1965.JPG IMG_1969.JPG IMG_1972.JPG IMG_1973.JPG IMG_1966.JPG
  7. 55crownvic
    55crownvic Member
    colorado springs
    I forgot to mention that I did not use their vent hole, I plugged it and vented my tank via the filler tube, installed a fitting at the top of the tube and ran a hose to the trunk floor for the vent. I did order the pump with the optional vent, but the darn thing leaked fuel, so I nixed that.
  8. 7D2 Grabber
    7D2 Grabber Member
    My spectra F30 tank came in and so did my aeromotive phantom 340 in tank.
    Measure twice cut once, 3 1/4 hole for the pump.
    The tank is 9 1/2 inches deep at this point. Add an inch to the foam and make the cut.
    Use the template and drill the holes.
    Make the cut to the bracket at 9 1/2, cut the plastic tube accordingly and connect the pump. Make sure you clean out the metal shavings from the tank and install.
    tody likes this.
  9. 7D2 Grabber
    7D2 Grabber Member
    Test fitting the tank the body today. The 45 -8 fitting hit on the hump. I reclocked it one over and the return straight -6 hit but was better. Pulled the BFH and a rounded body working dolly and went to work. Made enough room without it being too noticeable. An old rubber shock bushing works good I between the tank and floor for a little extra room.
  10. 71Mavrk
    71Mavrk Member
    Nevada
    Since I ran my hoses to the front of the tank, I did not have the clearance issues.
    Micah
  11. 7D2 Grabber
    7D2 Grabber Member
    Where did you run your vent tube?
    I ordered this from tanks inc.
  12. 71Mavrk
    71Mavrk Member
    Nevada
    They offer a vent tube with a check valve. I connected it to the original vent line to the canister.
    Micah
  13. 7D2 Grabber
    7D2 Grabber Member
    Did you run an inertia switch to the pump?
  14. 55crownvic
    55crownvic Member
    colorado springs
    Thats what I did with mine, but it didnt stop the gas from spilling out, was worthless for me, maybe you will have a different outcome. Hope so.
  15. 71Mavrk
    71Mavrk Member
    Nevada
    No issues with the vent tube after 3,000 miles. Is your spillage during fill up? Maybe your line is plugged.
    Inertia switch is part of the Ford Racing harness. Mine is mounted near the computer in the passenger compartment. It controls a relay mounted in the trunk. Power is from the trunk mounted battery with marine breakers providing protection and switching.
    Micah
