afr 165 heads
Discussion in 'Technical' started by MaverickDan, Aug 27, 2010.
  1. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I was looking at an article today saying that adding afr 165 heads on a stock block will add 100 hp. Well after reading it I decided I would like to do this to my car over the winter. When I was looking at prices I notice the is different size chambers. Would 58cc chamber head make more power than the 60cc head? I would like to keep the c/r low enough to run pump gas. Also my piston are flat top no valve reliefs, has anyone used a piston fly cutter, and how hard is it to use? Any way heres the article I found http://www.carcraft.com/techarticles/116_0307_ford_302_v8_engine_buildup/index.html
  2. Mavman72
    If you put 58cc heads on a stock 73 engine. Your compression will end up near 9:1
    The 60cc heads will not let you achieve better than 8.7:1 73 blocks have a tall deck. This was done to kill compression (smog era had begun).BUt... By virtue of the AFR heads better breathing capacity, you will see a performance gain regardless of nominal compression ratio. If you optimise the engine to utilize the heads to their fullest (cam profile/headers,exhaust/induction)etc...You could build a pretty solid little screamer...
  3. PaulS
    To answer your question more directly - the 58CC chambered heads will make more power than the 60CC chambered heads. Their breathing is nearly identical and the higher compression will give slightly more power.
    In order to get 100 extra hp you will have to add a new cam and lifters. Your stock cam will not provide enough air flow to increase the hp to the 100 hp mark.
  4. maverick75
    Get a cam/intake and go with the non smog 185s.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I forgot to mention I have an 88 non h.o. roller motor with a b303 cam in it with a performer rpm air gap intake and e7te head currently on it. I was aslo planning on using 1.7 ratio roller rockers
  6. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    As far as fly cutting its not that difficult, but I'm wondering what pistons you have................ Shouldn't the 88 motor have valve reliefs in it? Or do you have aftermarket pistons?
    Theres another method other than buying a flycutting tool involves using a 2.02 valve and some sand paper.
    I also agree with above, If you can afford it step up to the 185's. Alot more room to grow and can even be usefule down the road if you plan on a stroker motor, or even a 351.
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    The 302 is from a crown vic that had e6se heads. I guess because the e6 head chambers are so deep ford decided that they didnt need any valve reliefs.
  8. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    Oh ok, I missed that part. Let me look and see if I can find you a how to on another method without buying the fly cut tool, I will post you a link.
  9. maverick75
    Trick Flow Twisted Wedge :D
  10. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    Heres a good article on fly cutting method with some tricks, I'm still looking for the other method but the more I think about it I've only seen that method used on pistons already with valve reliefs that just need a bit of extra clearance. Not putting reliefs into flat tops.
    http://sbftech.com/index.php/topic,2124.0.html
  11. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    A VERY true statement once you figure in price of tool, and time to do it.
    Also a great cylinder head, the OP should investigate this a bit(y)
  12. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
  13. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Dont the twisted wedge heads need matching pistons to go with them?
  14. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    If you never plan on building a big inch stroker motor, don't waste your money on the 185's.
  15. bmcdaniel
    That article has been debated for years. No one else has been able to duplicate the results. Did sell a lot of magazines and heads though...
    Stock flat top pistons may not have enough material to add reliefs.
