After market radiator
Discussion in 'Technical' started by 0nealprince, Apr 29, 2012.
  1. 0nealprince
    0nealprince Member
    north alabama
    1972 comet
    Does anyone have a suggestion for this up grade?
  2. mojo
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    But, if you're looking for a good-looking, good fitting, well-built, super-cooling aluminum radiator you'll like that one.:thumbs2:
  4. Mavman72
    Yup...Its an excellent radiator...
  5. Sherrod
    Sherrod Member
    73 mav 250
    I got a champion 4 core for my 250 =). It looks awesome!! Best bang for your bucks.
  6. John Holden
    John Holden Member
    NJ
    I just installed my champion radiator and I had to file the holes to raise the radiator up because the lower hose fitting was hitting the crossmember.
  7. Jsarnold
    '72 Sprint
    I talked to the guy that jimmy2gates referred me to (don't recall his name) at Champion about the lower hose clearance. Mine JUST clears. The close fit was intentional to get the maximum tank size.
    The other issue is the petcock might hit the front cross member. You might need to remove the petcock and use a pipe plug or notch the crossmember for clearance. I notched the crossmember and put a street elbow in to turn down the drain to make it easy to catch the coolant when draining.
  8. John Holden
    John Holden Member
    NJ
    I'm just hoping my hood doesn't hit the rad!
  9. mojo
    That's a gud idea. I just had my rad out and did'nt think abt the elbow. I recall u mentioning the mod b4, but had forgot abt it. I hope I can remember it the nx time I have the rad out. "No time soon - I hope".
    My rad came w/ the plug, but I still had to notch the Xmember. I need to notch it more, can't get the plug all the way out w/ the rad bolted in.
  10. mojo
    I don't think ur rad will have any hood clearance issues unless u raised it up quite high. I did'nt have any problem w/ my lower hose fitting hitting the Xmember. Maybe they have made some changes in the units since I got mine. I believe I have a 3 core. How many cores do u have?
  11. John Holden
    John Holden Member
    NJ
    Probably the three row. I know I opted for the more expensive one.
  12. mojo
    My rad bolted in "direct fit". The only mods I wud have had to make was If I had used my engine driven fan setup. I did'nt see how my stock shroud wud bolt in w/o some kind of mods. I have seen other folks use their stock setup on these rads. I don't know if they are using the exact same rad. Anyway, since I was going to elec fan setup, was not an issue...
  13. Jsarnold
    '72 Sprint
    I had NO fitment issues with the OE V8 AC shroud. It did bolt right up with no fuss. (I've since installed the Taurus electric fan.)
  14. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    My Champion 3 row most likely would have bolted up directly if my front end wasn't all bent up from a previous owner's incident with a ditch. The aluminum tabs with the extra holes make it really easy to install an aftermarket adjustable frame type electric fan. Great radiator.
  15. thegalindo
    thegalindo Member
    Fontana, CA
    Maverick 1976
    Thank u, i just had a problem with my 302 i installed 351 heads and i had to use 351 head gaskets instead of a 302 head gaskets now the machine shop guy adviced me to replace my radiator for a 3 row due to the high flow issue with the heads. Now this champion rad would be the one im looking for. Thanks again. Just an advice DO NOT try putting 351 heads on your 302 to save money adding some hp, please choose to go for the aftermarket stuff the hassle and problems you will have... man just put some bucks on your project it's worth it.
