Aftermarket quarter panels
Discussion in 'General Maverick/Comet' started by orig72 grabber, Jan 26, 2016.
  1. orig72 grabber
    orig72 grabber Member
    Innisfil, Ontario
    72 Maverick Grabber, 72 Comet GT, 74 Comet GT
    Does anyone know how far up the quarters the aftermarket panels go. Do they reach to the bottom of the back window and to the rear corner of the quarter glass, or do they stop short of that. Have never used the aftermarket ones and am curious as to use them or hold out for a good used set of quarters.
    One quarter on my car has already been replaced and was cut at middle of the bend in the boomerang moulding, need a replacement to go higher than that.
  2. Craig Selvey
    You will really want original quarters.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The aftermarket replacements do not go that far, they reach the top body line and what goes past there has no resemblance to the shape of the car. They are also very different at the bottom where it meets the trunk drop as well as where it turns up to meet the bumper/valance.
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    So what you are saying is that they are only good for sheet metal patches here and there?
  5. mav1970
    That is what I used mine for once I found that they were not close enough to original to use as direct replacements
  6. RMiller
    Kennewick, WA
    Wasn't saying that at all, just pointing out where they fall short. Even using them as patch panels you will still have to deal with the areas that are not the same as the originals. I took care of my rust issues by getting a different car so I didn't end up using these!
  7. orig72 grabber
    Innisfil, Ontario
    thanks for the input, dont think I want to use one of those, time to blow the dust off the shear, brake ,roller, shrinker/stretcher and tig welder, I can make nicer patch panels for less.
