Aftermarket Radiators that fit?
Discussion in 'General Maverick/Comet' started by 55crownvic, Oct 19, 2014.
  1. 55crownvic
    55crownvic Member
    colorado springs
  2. Acornridgeman
    Wisconsin
    I just put in an Engineered Cooling Products radiator in the '72 last week. It has 2 rows, but the cooling tubes are 2 times normal size and these will cool better than a 3 core small tube. I like the style of the rounded corner tank much better than the Champion tank. It fit fine, but I did need to add 2 mounting holes to line up with the Maverick mounting holes. Was able to modify a Mustang shroud to fit too.
    Shipped from Chicago. $199 plus shipping. They make both passenger and drivers side discharge (my '69 engine used passenger as pictured).
    http://www.speedcooling.com/radiators/cat_2.html
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Griffin makes a direct fit aluminum radiator. It's $630.00.
    http://www.summitracing.com/parts/gri-7-70036
    I don't know of any $200.00 aftermarket radiator that actually bolts right in and has the hose fittings in the correct place. You get what you pay for.
  4. Acornridgeman
    Wisconsin
    You know about one now .......... :evilsmile:
    No trouble with hoses or petcock. Bolted up fine to the car, but I needed to add 2 holes for the shroud and modify the shroud bottom slightly for the fan I'm using.
    Here is a pic in the car
  5. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    I bought my champion racing one 2 years ago no issues at all I think I bought the 3 row
  6. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    If these 2 rows can keep up with a strong 302, I would think it would allow additional clearance for an electric fan & shroud. From what I have read on the forum, clearance can be very tight.
  8. Acornridgeman
    Wisconsin
  9. rotorr22
    rotorr22 Member
    Columbiana, Ohio
  10. Acornridgeman
    Wisconsin
    The 340 - but let me be clear, my engine is a 1969 and has the water pump that uses the passenger side inlet and outlet. They have one that is the same 22" radiator but has an outlet on the drivers side - that number is a 339
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The lower hose outlet is in the wrong place and so is the petcock valve.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I'm running a stock Maverick Shroud and fan. Will it fit that?
  13. Acornridgeman
    Wisconsin
    I have a Mustang/Cougar shroud and an oversize SFI fan. If that fits, why wouldn't the Maverick one?
  14. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I naught one off eBay that is great.
  15. 71gold
    I'm a Champion Radiator Guy. I've had three or four different ones in my Mav. Tim has one in his Mav. and notched the strut brace for the petcock.
