Air Cleaner for my 250 v6
Discussion in 'General Maverick/Comet' started by 4DoorMav74, Apr 18, 2007.
  1. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    1974 four door Maverick
    im lookin for a nice chrome Air cleaner for my 1974 250 6 cyl in-line Mav. i have a Holley one but its too tall and doesnt fit under the hood... anyone have any suggestions on what ones WOULD fit? if anyone have a nice chrome one ill trade em my holley one its still in the box and everything... Thanks (y)
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    The 250 V6 Mavericks were very rare. 'Might be hard to find a chrome breather for that. ;)
    A "previous owner" massaged the lower plate on mine to allow the breather to sit lower. 'Worked out nicely (if no one has another answer for you).
    p.s. You probably have an "in-line" 250cid 6 cyl.
  3. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    any idea how he did it? i like the Holley Air cleaner i have just find it stupid to cut a hole in my hood unless i have an Air scoop or sumthin...:(
  4. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Your gonna have a hard time with that one, ford even used shorter carbs with the 250 to make it fit under the hood. I wish i knew someone who made one, i just left the stock one on the 250 i had. At least it fit.
  5. 4DoorMav74
    4DoorMav74 Youngin'
    Oceanside CA
    yeah its just the stock one is so ugly lol wanna have a chrome one : /
  6. HellsChevelle
    HellsChevelle New Member
    Mesquite
    1977 maverick v8Swap in Progress
    ya i have the same problem except mine is a 1977 i bought the same breather for mine nice and chrome but it doesnt fit...i need about another 2inches for it to clear but even taking the plate clear off doesnt give it enough clearance
  7. newtoford
    newtoford Member
    New Castle Delaware
    i used one of those really tiny chrome 4''(i believe) open element cleaners, but with out the scoop theres no way it would have fit. there really arent many options with out cutting a hole, even then the carb isnt centered in the engine bay like on a v8. its a little too "import" for me but one of those cold air set-ups with the long tube with the filter on the end would probably fit nicley down next to the batery
  8. newtoford
    newtoford Member
    New Castle Delaware
    this would probably be your best bet. mustangs never had the 250 though, just 200's or less. since the 250 is 2-3'' taller you still might be having clearance issues.if it didnt fit use the base of your original aircleaner, cut off the "excess" and use the new filter and chrome lid.
    http://www.mustangsunlimited.com/itemdy00.asp?T1=AC3+01
  9. Rick Book
    Rick Book Member
    Thailand
    I'll look when I get home or he (Dan Hines) can post up how he managed it if he sees this thread.
    I agree. Please do not cut a hole in your hood.
  10. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I used the chrome air cleaner from Mustangs' Unlimited on my 250. I had to enlarge the carb opening in the base and cut an additional relief to clear the choke housing to get it to fit. It is VERY tight under the hood...in fact one corner of the air cleaner barely touches the underside of the hood. I also had to grind the wingnut down to clear the hood, but it works.
  11. Maverick Man
    California
    you also can get the one bbl adapters from Spectre then use your drop base air cleaner
  12. newtoford
    newtoford Member
    New Castle Delaware
    thats a very nice looking engine gene, what kind of dizzy is that? it sits alot higher than a stock one.
    im currently trying to find an air cleaner set up also. the new carb is a 2bbl and the base of the cleaner is more of an oval shape compared to a 1bbl or 4bl carb
  13. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    It's the Ford Six Performance DUI electronic distributor from www.classicinlines.com
    It's very similar to the...ahem...GM style with the coil and ignition module all located under the cap. Starts and runs smooth. :thumbs2:
  14. JnkYdMod
    JnkYdMod Member
    Curlew Washington
    1976 Maverick
    I've seen this option, and is what I plan to do with mine. Use the original base that is, and go with an open element. I think it looks as good as anything else:thumbs2:
    Lou
  15. draggon13
    draggon13 Member
    Hilliard, Florida
    1974 Maverick V8 5 Speed
    Incorrect, the 250 came out in 69 and was available in the Mustang, my friend's sister owned and L code 250 69 sportsroof, fastback for those who call them that as well. And it got great gas mileage, about 25 on the highway, go figure light car, no options and a 2.79 rear gear.
    rk
