Air Conditioner Problem
Discussion in 'Technical' started by MayorMav, Aug 25, 2009.
  1. MayorMav
    MayorMav New Member
    Vinton, VA
    I have a 1971 Maverick with factory air contitioning. It is leaking into the passenger side floor area. Does anyone know where the drain to the outside should be located. A diagram or picture would be extremely helpful. Thanks - MayorMav
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I expect its the same as my '72. Mine exits in the right front of the transmission tunnel. Looks like a heater hose that's open to the under side. Hose is just a few inches long and attaches to a nipple on the fiberglass case under the dash on the passenger side. You should be able to see it or feel it up under the case by the tunnel. Other posts have reported that the nipple sometime breaks off from the case. Mine was just not attached.:hmmm:
