Alternator spark
Discussion in 'General Maverick/Comet' started by DocRoche, Jul 24, 2016.
  1. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Got home from nationals and went out to check my transmission fluid level (I had previously fixed some leaks). As I was shifting through the gears I noticed a spark shoot up from where the alternator is. Went to investigate and saw this. At first I thought it was the negative battery cable to close to the alternator. But small spark stayed there after I moved the cable. Any ideas? Could be something simple like just cleaning the bolt. But wanted an opinion.
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I have never seen that before, but it would appear that your alternator has a short to the case, and the case is shorting to the bracket. The charge wire attaches to the rear of the alternator. I would inspect the harness and connection looking for breaks in the wire casing or problems where the charge wire attaches to the alternator. You may have to replace the alternator, the harness, or both. Hopefully someone more knowledgeable will respond. Glad you got the transmission back together. How is it working?
  3. DocRoche
    DocRoche Member
    1973 Ford Maverick
    So far so good. No leaks. Put the new transmission pan on. Came home to no leaks but the spark kinda hit me in my moment of triumph lol. Thanks for your help.
  4. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Heres a different picture where the spark happens. You can see it looks like the bolt and bracket are welded together from where the spark happens. Update, I think the alternator was dying cause now the car wont start. Like it just died. Ill have it tested this week.
  5. Krazy Comet
    Nothing more than a bad ground, remove and clean it up... The arcing can damage the rectifiers...
    DocRoche and Hotrock like this.
  6. Hotrock
    Munroe Falls, Ohio
    Tom knows his electrical positives and negatives.
    DocRoche likes this.
  7. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Ill do that. Thanks for the advice!
  8. DocRoche
    DocRoche Member
    1973 Ford Maverick
    This may be a stupid question, but as I was taking this apart I noticed that the top bolt wasn't connected to the alternator. If you look at the second picture, shouldn't that bolt go through the square piece on the bottom right corner of the picture?
  9. 71gold
    what did it go through?
  10. DocRoche
    DocRoche Member
    1973 Ford Maverick
    There was a bolt that was just connected to the engine harness. Looks like the previous bolt was cut and the bottom half of the bolt was still in the alternator.
  11. Krazy Comet
    Yeah you are correct bolt should go through the ear on alt, apparently the belt is too long...
    Still sparks are due to bad ground condition...
  12. DocRoche
    DocRoche Member
    1973 Ford Maverick
    I was inspecting the wire harness and it looks fried. Any idea where I could find a replacement? Didn't see one at Oreilly
  13. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Upgrade to a 1-wire alt. Pretty easy and gets rid of a lot of clutter.
  14. DocRoche
    DocRoche Member
    1973 Ford Maverick
    That's a good idea, thank you.
  15. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Melvin's sells them.
