Can someone please explain to me the correct way to wire up the 100a alternator I picked up. This is a link to Schucks that sells the alt. I picked it up from the JY and I can't get a 12v+ reading on the volt meter while the car is running. I have it hooked up to the voltage regulator the regular way, but it does not seem to be charging the battery. Here is the link. http://www.partsamerica.com/product...TR&MfrPartNumber=A7303259&PartType=11&PTSet=A
It should wire up the exact same way your old one came out. If your regulator bad? Did they sell you a defective alt? Your car is externally regulated right?
Yeah the car is ext regulated. I had the alt checked and it was fine. I'm stumped. I guess the regulator could be bad.
