AM Radio Speaker
Discussion in 'Technical' started by CDL, Jan 9, 2015.
  1. CDL
    CDL Member
    Does anyone know what ohms is the am radio speaker?
    Thanks
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    The original 5 x 7 dash speaker ... according to the Ford Parts Manual, 70-71 was 8.0 ohm. 72 was 3.2 ohm..... ohms not listed for 73-77.
  3. CDL
    CDL Member
    Ha - the radio I have is from a 1973..
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Real easy to check with a ohm meter.
  5. CDL
    CDL Member
    Really, ok do i turn on the radio and check ohms on the wires?
  6. injectedmav
    injectedmav Member
    Georgia
    No, unplug the speaker and touch a meter lead one to one wire leading to the speaker and the other lead to the other and set your meter to 0-20 ohms and see what it reads. If it's auto-ranging, you just set it to ohms.
  7. CDL
    CDL Member
    Oh ok but that would only work if I had a speaker. That was my question, really. What speaker should I buy for a Ford 1973 AM radio? 4 or 8 Ohm?
  8. Krazy Comet
    I'd go with the 8 ohm, radio won't really care if it's rated for four ohms, but a eight ohm radio may not be happy with a four ohm speaker...
    BTW a speaker cannot really be measured accurately with the DC meter that we're all gonna have, generally going to read around 25-30% low...
  9. CDL
    CDL Member
    I know this.. if the radio is rated 4 ohm and I use an 8 ohm, then the radio could overheat and damage internals, but if it's rated 8 ohm and I use a 4 ohm speaker, the sound won't be good but no damage to the radio.
  10. Krazy Comet
    Nope you got it backwards, 4 ohm is twice the load of 8...
    Yeah I know it may seem backwards but that's correct(I worked electronics for almost 40 years)...
  11. CDL
    CDL Member
    Well I was close..hehe
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    My '74 is 3.2 ohms also. Read it right off of the speaker.
  13. CDL
    CDL Member
    Thanks i'll try that since a 72 and 74 is a 4 ohm
