an electrical puzzle.
Discussion in 'General Maverick/Comet' started by ptpdub, Jun 28, 2010.
  1. ptpdub
    ptpdub Member
    canada Sk.
    so the car is almost finished. i was putting the finishing touches on it tonight and i replaced the signal flasher that was not working. i put in a new one and ..... no flashing. the lights turn on but wont flash. so i pull out the flasher and go over to bench test it. i got the identical light (l.e.d.) and ran power threw the flasher. no flash. then i put an old 11/57 on the same cercut and it flashes just fine. so the L.E.D. dosent draw enough current to engage the flasher. i hid an 11/57 bulb in line to get the flasher working and it works fine now but i don't want to do this. i want to fix the problem correctly. so how do i do it? is there a L.E.D. specific flasher? can i find a way to create the proper draw on the cercut with out hiding an additional bulb? (if so then how?) some other option i haven't thought of? what do you think?
  2. maverick75
    To run LED's you need to use an electronic flasher.
  3. ptpdub
    ptpdub Member
    canada Sk.
    OK, i am in a small town and none of the parts stores here (3 only) have any idea where i can get an electronic flasher any web sights that i can buy one from? i don't actually know what i am looking for so i will need an exact link.
    thank you for your time.
  4. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
    at the bottom of this page superbrightleds.com they look to have what you need.
  5. ptpdub
    ptpdub Member
    canada Sk.
    sweet. thank you
  6. maverick75
    i see them all the time at our parts stores, They're in the DIY electrical section, You'll need the two terminal one like this:
    if you have a NAPA up there they should be able to order it for you. :Handshake
    part # NF 552LL
    Oreily is
    FL32
    Autozone is
    EL12
