Another newbie
Discussion in 'New Members Forum' started by pro70mav, Oct 20, 2004.
  1. pro70mav
    pro70mav Member
    70 maverick
    Hello, I'm Steve and I live in Logansport, LA I have a 1970 Maverick, mainly all I do is drag race. I have a 351w with a mightymite C-4 and still run the 8 inch with 4.11 and a minispool. It was a one owner with 49,000 miles on it with a 6 cylinder with a 3 speed, shouldnt have gutted it but I got the go fast bug. It has run a best of 10.90@123 but I still run the 302 headers,dang shocktowers. My future plans is to swap to ifs and put some real headers on it, and go to a 9 inch. Then spray it with 150 shot and run 9's!!!! Hey it sounds good anyway! Nice to be somewhere where i'm not the oddball running a maverick!
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Welcome to the board.
  3. don graham
    welcome to the board steve. surprised the mini spool has held up so well. good luck on the 9's. keep us informed.:)
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    These Maverick people seem to be coming out of the woodwork lately. I think it's great...
    (y)
  5. pro70mav
    pro70mav Member
    70 maverick
    Thanks
    Thanks yall, I had to put longer studs and open-ended nuts and when I got the axles out they looked a little twisted, not real bad though. Guess a transbrake and slick might do that.:D But I know when I spray it something will break,It already does a 1.49 best 1.50 consistent short time!
  6. don graham
    i went for the overkill. i'm running 12.08 at 114 with a 302. but i've got a 9" with full spool and 33 spline moser axels. 4.33 richmond gears. only wanted 31 spline axels but at the time moser didn't warranty them, yet the 33's were warrantied for 10 years and they were the same price. :)
  7. Mavaholic
    Sweeeeeet! Welcome to our little cornor of the internet.
  8. Jean Doll
    Palmerton, PA
    Welcome to the board Steve.
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Welcome!! and there is plenty of oddballs here. Me included
    Dan
  10. pro70mav
    pro70mav Member
    70 maverick
    Thanks for all the replies. Good to be here!:cool:
  11. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Steve, have you ever been to the FFW in Houston? I might've seen you there (hanging out with Ivy)?
  12. DanielBoone
    DanielBoone New Member
    302 or 351?
    :confused: I know you can drop a 302 in a Maverick. But, a 351? Do you have make any modifications to the frame, motormounts, shocktowers, firewall, springs etc. I bet changing spark plugs can be a real hassle. Do 302's and 351's have the same block width? I have seen some stroker 302's that make 347 ci. That sounds pretty good if a 351 block is wider than a 302.
  13. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Welcome! Use the search function for 351W swap. Lots of discussions about it. But to generally answer your question, yes a 351W will fit, and no they are not the same width, the 351W is wider than the 302.
    -Corbin
  14. pro70mav
    pro70mav Member
    70 maverick
    Nope never been to the FFW. I just met Ivy here recently while racing at the new track in Diboll,TX PVR. He's a nice fellow, real sharp to not much he don't know bout an old Ford! Just got back from the track with a new best of 10.83@123.80 1.47 60' 6.85 1/8 not to bad for an old FORD, boy I love it:bananaman :D :D :D :D :D
  15. Mercurycruizers
    Venetia, PA
    Yes a 351 will fit. It's one inch taller & one inch wider than a 302. It will fit without touching the shock towers. Cliff in Vancouver B.C. did the conversion. Looks great. He used 302 headers. I asked about changing the plugs also. He said he pulls the valve covers & it takes about 45 minutes to change the plugs. He goes by Grabber71. Haven't seen him on here in awhile. Where you at Cliff?
