another oil sending unit ?
Discussion in 'Technical' started by 390S302, May 30, 2007.
  1. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    I got on of those summit 5in tach it came with all the hardware, but i still cannot get the oil sending unit to go into the 302 block. I even went to local ford dealer and they sold me an oil sending unit for a 302.
    The problem is it starts to thread in and after about two threads it pops out of the block. Does anyone know the inside diameter I tried 1/2in and it still did not fit. Or could it be how the orginal hole was drilled? Or could it be a metric block?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. 390S302
    390S302 Member
    No not yet if another idea does not work. What size is the part that goes into the block. I bought alot of pipe bushings and fittings today would like to only buy one if possible.
  4. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Ummmmm.....maybe I missed something, but why are needing to connect a tach to the oil sending unit? :hmmm:
  5. PaulS
    The oil passage in the SBF is 1/8" npt. It is close to 3/8" outside diameter.
    If you are having a hard time with it try running an eighth inch pipe tap in first. (this info is for the US cars - I don't know whether the foreign Fords are the same)
  6. 71gold
    i was :hmmm: the same thing...:huh:
    ...:bouncy:...
  7. 390S302
    390S302 Member
    Because it is a Summit 4 in 1 tach not 5in 1 the tach has an oil gague, volt meter,water temp all built inside. Summit part number sum-800104k. Hopefully that helps
  8. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Ahhhh...that just bridged the non-sequiter gap.....
  9. 390S302
    390S302 Member
    A light at the end of the small tunnel got wrong fitting after all went to plumbing store got right one with extension and now I have an oil sending unit.
    Thanks for the help with the picture
  10. grbmaverickmo
    Aquashicola, PA
    Thats one fancy tach you got there
