Another question here
Discussion in 'Technical' started by adam 72, Dec 21, 2011.
  1. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    When a carburetor is being swapped, does the manifold need to be changed or does the adapter address this problem? I thought the adapter made it possible to use with the current manifold, but my dad thought It needs a different manifold. Should I just go with a new manifold anyways?
    Thanks again
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If it is a 6 cyl you can't swap manifolds.
    If it is a v8 and you are referring to installing a 4 barrel carb using an adapter on the existing 2 barrel intake. In my opinion your wasting your money. Swap the manifold to get the maximum benefit.
  3. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well I have the six so that cuts my options down a bit. So to swap manifolds, one would need to replace the cylinder heads and the manifold? I feel like I'm liking the adapter idea ha.
  4. Craig Selvey
    What carb are you trying to put on your engine....and why?
  5. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well I was looking at the Webber progressive two bbl set up. And just wwant additional information
  6. Craig Selvey
    How many other mods are you planning to do to this engine? Unless you are planning on headers, a cam, and other mods....I don't think you will gain a lot with a two barrel carb.
  7. indyman13
    indyman13 Member
    Little Rock, Arkansas
    The adapter will work on your existing 6 cylinder manifold but will restrict the flow of the progressive 2bbl unless you have the intake on the manifold machined. I noticed a slight improvement in mine without the machine work but still can't spin the wheels. It also tends to run a little rich so re-jetting the carb might be an option.
  8. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I figured it'd need a lot of work to notice a major difference I jist wamted to try something new
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Is there a link available that discusses price of v8 swap or any recommendations for a certain type of v8
  10. gmatthew76
    gmatthew76 Member
    Freeport, Fl
    1976 2 dr Maverick, 1977 2dr Maverick,1998 Ranger, 2004 Focus Wagon
    Check out this site. Loads of good info on ford strait six performance.
    http://www.fordsix.com/tech.php
  11. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Thanks. The carb section took me bback to classic inlines where i was reading ha. Thanks
