Another question
Discussion in 'General Maverick/Comet' started by SamsDad, Jun 24, 2014.
  1. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    Anyone tell me the best way to block off the oil dip stick access hole on the side of the roller block, I am using the timing cover dipstick access seeing as the roller oil pans won't work with the Mav. frame, now I need to seal a hole?
  2. 71gold
    some use a small freeze plug...:yup:
  3. SamsDad
    SamsDad Member
    Little Rock, Ar
    thanks
    will do, thanks so much
  4. bmcdaniel
    I used RTV.
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I plan on tapping the hole and installing a plug.
  6. Bryant
    i tap the hole with a pipe thread tap and put a pipe plug in the hole.
  7. SamsDad
    SamsDad Member
    Little Rock, Ar
    Thanks
    All good ideas, I'll use one of them for sure, the tapping sounds the most secure so far
