Another Radiator Question
Discussion in 'Technical' started by mercman53, Jun 11, 2008.
  1. mercman53
    mercman53 Member
    Watsonville Ca
    Maverick
    I've got a 71 200CID and was wondering if the radiator is supposed to spit out water out through the top when the cap is off? Is this normal? Just wondering. I think my temp gage is no good as I installed a New Sending unit but it still goes straight hot once I turn it on. Any and all opinions and thoughts welcome.
    Thanks, another new guy.
  2. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    If the gauge goes straight to hot when the key is turned on, your wire from the sending unit may be grounding out.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    some one say radiator:D:naughty:
    inside joke:hmmm:
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    When the engine is warm and the thermostat is open there is a constant flow of water through the radiator. SInce the water enters on the top it is possible for it to spill/spit out of the top. (Mine does on occasion) What you don't want is surging of the water level or large, continuous bubbles. (signs of head gaskget issues?) I also agree with the gauge question. In my experience most electrical issues for me anyways seem to ALWAYS be a bad ground!
  5. PaulS
    If your engine is over-heating right away you may have a defective thermostat or it may be install backwards.
