another rear end ???
Discussion in 'Technical' started by scrapper60, Jul 30, 2008.
  1. scrapper60
    scrapper60 MCCI Member
    Alabama
    Are the u joint caps the same for a 9" rear as they are for an 8"? I'm using my stock driveshaft. If not, does someone know if they make a u joint to fit the stock driveshaft and the 9" yoke.
    Thanks,
    Jerry
  2. PaulS
    Yes there is a Ujoint that has both size caps on it. It was used by Ford on some of their models so it is quite common.
  3. scrapper60
    Alabama
    Do you have any numbers or other reference I could ask for at the parts store?
  4. PaulS
    no, not off the top of my head but I am sure someone will have it.
    If not the parts technician may know easily what you need.
  5. Old Guy
    Old Guy Member
    Try this Jerry--PDQ#1-0134
  6. Blown 5.0
    MS.
    1974 Maverick
  7. Rick
    Rick G8I operations
    Ocala, Florida
    I used the Precision 353 to convert from 1310 to 1330 you can also use a Spicer 5-134X
  8. scrapper60
    Alabama
    Wow, thanks a lot gentlemen. Simply amazing.
    Jerry
  9. PaulS
    These guys are good aren't they!
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    opposite that is the precesion 331 or 347......I cant remember just that it was a stroker number:idea:
    Using a large shaft with the small 8 inch pinion....
  11. Rick
    Rick G8I operations
    Ocala, Florida
    There are several part numbers for this size joint
  12. baddad457
    There are combination U joints for just about anything.
  13. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    If all else fails "oops that was boxed wrong" at the parts store. lol I've seen that before when they swapped caps for someone. lol
