Another snapped Head Bolt!#*$
Discussion in 'Technical' started by Resto, Aug 5, 2011.
  1. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Is it possible that the head on my 250 I6 is very warped? :mad:
  2. Bryant
    a warped head wont brake head bolts. either your over torquing them or they are used and weaken. either way if you broke one or more you need to get a new set and make sure that your torque wrench is accurate.
  3. strokermaverick
    strokermaverick Member
    Make sure your headbolt and bolt hole threads are clean. Debree on either can snap a head bolt.
  4. Craig Selvey
    Did you snap the one I sent you...or another one?
  5. Resto
    Yuma AZ
    No Bro it was another one. I put the one I got from you in #2, I snapped # 10 in the third round, I rented a T-wrench and the head of the wrench was loose, same as mine. No big deal though. My God son and I were already gonna drop a 351W in it anyway. We'll start on the restoration of the engine bay while we're waiting for the motor.:)
  6. Resto
    Yuma AZ
    No I didn't have the head checked I thought about it because the motor was severely overheated and blew the head gasket. I followed the torque sequence both times. I suspect the wrench. But no big I was gonna drop in a 351W anyway. My Godson and I thought It might be fun to try and burn the tires with the 6. However we really want to get started with the restoration.:)
    PS I gonna buy a top of the line T-Wrench for this V8.:rofl2:
  7. Craig Selvey
    I have more bolts if you need them.
  8. 71gold
    maybe that weakened the bolts...:yup:
  9. Streamliner
    Streamliner Member
  10. simple man
    simple man Member
    Bunnell,Florida
    If your engine was overheated get another set of head bolts! What happens is two things, the bolts stretch because the block and head expand when overheated, and the actual metal structure has been compromised! I'm sure someone here has a set!:)
