Another transmission fluid question
Discussion in 'Transmissions' started by 3154tm, May 8, 2014.
  1. 3154tm
    3154tm Member
    hi all,i had to drain my C4 and now i can't remember which ATF i put in last time i filled it. it was either Type F or Dexron III/M. i'd like to refill it with Type F. if it had the Dexron in it is this going to cause a problem?thanks.
  2. stuarta
    stuarta Member
    Moose Jaw Saskatchewan
    2008 Ranger
    How many forums are you going to ask this question?
    Richard Kuss likes this.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I'd drain the Dexron out of there simply because the clutch material is not designed for it. I know it does not hurt to mix Dexron and Type-F in GM transmissions.
  4. 71gold
    has the transmission been rebuilt?
