antifreeze leak
Discussion in 'Technical' started by maverick7072, Feb 14, 2014.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I think the driver side head is leaking on the outside but no internal.Is this possible?the oil is clean .the small puddle shows up on the top of the timing cover and looks to be dripping at the corner of the head next to the distributor .at 1st I thought it was the thermostat housing but if it was it should have a puddle on both sides of the timing cover shouldn't it?you can kinda see where it dribbles down from the head and settles in the goove of the timing cover .is this a common problem? before anyone asked about the oil color there is no milking like substance or water on the plugs thanks for any thoughts
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    It could be the head gasket, but from what you describe its most likely the intake gasket, or t-stat housing. But the best way to find it would be to pressure test the cooling system that way your not just guessing.
  3. Krazy Comet
    Sounds like the intake gasket is leaking where it mates to the head... The part of the gasket that's exposed routes the leaking coolant to the outside of engine vs into oil...
  4. 71gold
    :hmmm:...intake/t-stat housing.
  5. scooper77515
    How bad?
    I just put a new timing cover on, and before I ran it it leaked a bit. Then after I got the engine running for 20 or 30 minutes, the leak has stopped.
    Mine was a slow drip somewhere around the top of the timing cover...
    Not sure if heating the engine caused the sealant to seal it or what.
  6. Moneymaker 1
    Panama City Florida
    i found out where a coolant leak was on my Aztek by using a UV dye in the cooling system, put it in, ran it to operating temp. and looked around with a small UV light, found it easily and the dye marks the path of the leak very well.
  7. Dave B
    Could it be coming from the weep hole, in the water pump?
  8. Mercurycruizers
    Venetia, PA
    I had that problem with my 302. Everytime I would take it down the 1/4 mile, I'd open the hood in the pits & coolant would be everywhere. I just couldn't figure it out. Only leaked when I put my foot in it at, the track. And couldn't track it down, cause it wouldn't leak any other time. Finally one day, I noticed a small leak on the passenger side head behind the alternator. I pulled the intake, so I could pull the head (figured it was head gasket). That's when I found out it was a small leak on the front corner of the intake. That was a relief & an easy fix...
    Hopefully that's all that's wrong with yours...
  9. scooper77515
    Why would it be the weephole? Brand new water pump...not that THAT means anything...
  10. 71gold
    that and wouldn't that leak under the pump?
  11. Krazy Comet
    Weep hole leaks on to the harmonic balancer not into the recess of the timing cover...
    Being it's on the DRIVER side I think Mercurycurser & my suggestions are by far the mostly likely...
  12. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    Krazy comet and mercurycruisers you guys are probably right I looked again closer and it seems like th eintake is seeping a bit ,its not a big leak but any leak is bad I just really had fluid leaks ,thanks for eveyones input
