Any electric wizards???
Discussion in 'Technical' started by comet666, Oct 21, 2007.
  1. comet666
    comet666 RAISE HELL AND DRINK WINE
    Sweden/Gothenburg
    Comet -74 Inline Six 250, 4.1 AT
    So the problems seem to never stop here in Sweden, yesterday everything in my car just lit up like a christmas tree, there was suddenly light in the ashtray compartment, I can see how fast I´m driving (light there as well), and even a light in the transmission "field", I was happy all day, but at the same time the button on the floor for the headlights stopped working, and the "lightbar"(the knob controlling the headlights/marker etc) is kind of unreliable, all the lights come on an off depending if I touch it just a little...
    Today the battery is completely dead (it´s just a few weeks old) and no lights inside work at all...:mad:
    Any ideas´??? :hmmm:
  2. comet666
    Sweden/Gothenburg
    One more thing, I need a fan shroud, shall I buy a 3" x 20" or the 5" x 20"...?
  3. baddad457
    Your headlight switch burned out. It sounds like it's grounded itself to the body, hence all the other lights coming on. The dimmer switch on the floor isn't working cause the headlight switch is burned out.
  4. Mavman72
    Is it a universal after market shroud?? or a factory replacement?? Sounds like aftermarket.Need more clarification on the dimensions.3" deep by 20" wide?? should be fine.I would think 5" depth will be a bit much.As long as it covers the whole core of the radiator and allows the fan to sit in the shroud a bit(like 1/2") you should be fine.Remember you dont want the fan totally inside the shroud(doesnt work efficiently like that)Ditto Baddad457 on the headlight switch.Good luck.
  5. comet666
    Sweden/Gothenburg
    Ok, but now what, I say to myself, suddenly everything works again, all the lights, my new carstereo, but now it won´t crank, All i hear is a ticking kind of noice when I try to crank it, tried to jumpstart it with my brothers car, but nothing happened...
    I must be doomed to walk in darknes...
    How come everything falls apart all the time, I fix one thing and then the next thing stops working, I like fixing stuff, but this electrical issues are killing me...
    Any ideas???
    Soon I gonna buy one of you a plane ticket to come see me and my comet so once and for all my troubles will stop..:huh:
  6. comet666
    Sweden/Gothenburg
    Great stuff, I´ll do some measuring...
    Thank you!!!!:)
  7. scooper77515
    If the headlight switch grounds out, it will drain your battery and you won't start.
    It really is amazing how much stuff goes through the headlight switch. Had one go out on my wife's 05 mustang, even the windows wouldn't go up all the way.
    About time to shoot you another care package?
    By the way, how did that carb work out?
  8. comet666
    Sweden/Gothenburg
    The carb is still sealed in the package!!!! I have had so many other problems since then, and they sure keep on coming, another package sounds like the only right thing!
    Must get stuff working before I can go to guy that helped me before to set the carb up, feels like it´s a risky mission for me to do it myself...
    So what do I need this time?, just got money as well, so if you are up for it let´s get down to business!!!
    Thanks!!!!
  9. scooper77515
    PM me with the list and we will get to shoppin':thumbs2:
  10. baddad457
    The battery is dead. Recharge it and replace the headlight switch and all should be well afterward.
  11. comet666
    Sweden/Gothenburg
    Bought the charger just now this evening, and Scott is sending me a new headlight switch, so hopefully It will at least crank tommorow morning!
    Thank you!!!
  12. comet666
    Sweden/Gothenburg
    Yes I forgot to tell you, it´s one of this chrome aftermarket ones, I don´t really know if I want one cause the price for shipping it here is awful, on e-bay I would pay 19 usd for the shroud and another 59 usd for shipping, gets kind of expensive for me, but if I need one I guess I have to save up some cash anyway...
    Maybe I should look for a factory replacement instead... really don´t know the difference.
    Thanks!!!
  13. Mavman72
    Factory style are made from fiberglass/aftermarket replacements are usally aluminum or steel or fiberglass depending on manufacturer and application.Have you tried to purchase an autoKrafters catalog.www.autokrafters.com.You will be in heavan when you get one,but then you will end up in the depths of hell when it comes to shipping costs.Good luck my freind hope this helps.:tiphat:
  14. comet666
    Sweden/Gothenburg
    Is not my car supposed to be cranking even with a broken headlight switch, I charged my battery but nothing happens, all the eletricity works, but when I try to crank all I hear is a large "click" from somewhere on the passenger side of the engine room...
    I guess I must be cursed...
    Please anyone???
  15. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    That is the starter solenoid clicking. It will do that if the battery is low, or if the electrical connections on the solenoid are dirty, preventing full current flow to the starter. It can also be that the starter is froze up, but from the sounds of it, the battery is probably just low. The bad headlight switch is doing is draining your battery, but it shouldn't be drawing enough current to keep the starter from turning.
