Any suggestions on brake lilghts
Discussion in 'Technical' started by lisaeyten, Apr 2, 2008.
  1. lisaeyten
    lisaeyten New Member
    Nebraska
    the brake light on the left side quit working, but I have turn signals, park lights and reverse. The brake light switch has power coming out, and everything is grounded. Anyone have any ideas?
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Howdy and :Welcome:The bulb is blown
  3. lisaeyten
    Nebraska
    bulb is new
  4. GTwannabe
    GTwannabe Member
    Acworth/Kennesaw, GA
    94 mustang GT, '73 Comet GT 302 toploader 4-speed
    is it the right bulb? 1157 or 2057
  5. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    put another bulb in and see if it works
  6. eddie1975
    Martinsburg, WV
    sold
    do you have power at the socket?
  7. myselfandiamho
    myselfandiamho Member
    hayden al
    1969.5 2dr 6cyl auto
    lisaeyten it is possible that the turn signal assembly is bad. check at the harness connecter under dash and see if you have juice there. the brake light switch puts juice to the assembly and the turn signal assembly sends it to each side. good luck.
  8. bmcdaniel
    bmcdaniel Senile Member
    That's my bet, too.
