Anybody seen this suspension by CPP yet or used it?
Discussion in 'Technical' started by maver88, Oct 17, 2017.
Tags:
  1. maver88
    maver88 Nick Taurone
    Russellville, AR
    1972 Ford Maverick 2-door & 1996 Ford F150 4wd w/ 429ci/granny low 4spd
    thinking about adapting this onto my Mav it designed for early mustang & falcons, bet I could modify the cross member to work on a Mav & with there tubular upper control arms its only $700, add some coil overs & one could eliminate a lot or all of the shock tower. Thoughts?
    http://www.ebay.com/itm/1967-70-FORD-MUSTANG-CPP-MINI-SUB-FRAME-KIT-UPPER-AND-LOWER-TUBULAR-ARMS/262485286613?_trkparms=aid=222007&algo=SIM.MBE&ao=2&asc=20160323102634&meid=d5ff36fb82af441e9146bf3520788ae8&pid=100623&rk=3&rkt=4&sd=282682763954&_trksid=p2047675.c100623.m-1
    which one would be closer the 64-66, 67-70 mustang, or the 61-65 falcon to the Maverick?
    I think the Falcon has the closest frame width correct?
    http://www.classicperform.com/Store2/Suspension/6466TCA-UKB.htm
  2. maver88
    Russellville, AR
    Well I guess that's a no lol
    Well get ready cause its gonna happen eventually & I'll do a Tech Article when I'm done!
    tbirdz12 and William623 like this.
  3. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    If you choose to do this, you will have a couple of changes you have to make. The front structural member that the strut rods connect to in a stock Maverick will have to be cut out to make room of the replacement plate. This will eliminate one of the primary strengthening structures on your front end. The plate you install will help a little but not enough as the dropped support member adds resistance to front end twisting that will not be replaced with a flat cross member.
    You would be better off starting with the 70 Mustang kit and just narrowing it to fit you frame rails. You will have to to measure carefully as the contours of the Mustang frame rails are not the same as the Maverick. You need to make sure the forward lower control arm mounting point is in the same relative position vertically as it would be in the Mustang. You may also need to address clearance for the crank pulley on the motor.
    Overall, the biggest problem will be reinforcing the front to resist twisting. Please take lots of pictures and tell us how it works out.
  4. bmcdaniel
  5. maver88
    Russellville, AR
    Jayman, yeah the 70 mustang was the one I figured on using cause the control arms are the same as our cars,
    and I plan on cutting the whole front cross member out and welding in some square tube & welding their cross member to it and the frame should be strong enough, gotta get the funs together for the kit first lol
    Grabber-1 likes this.
  6. maver88
    Russellville, AR
    Well I ordered my kit yesterday and should show up next week, not doing the coil overs just yet but will eventually to get rid of the shock towers
    junrai likes this.
  7. bmcdaniel
    Have you tried the mini subframe yet?
  8. maver88
    Russellville, AR
    Its under the car & sitting with just the body shell weight on it, fixing to spray paint on the whole car just been so busy trying to get it ready for paint
  9. maver88
    Russellville, AR
  10. mojo
    How will alignment process work w/ this setup? I am curious how this will be accomplished?
  11. maver88
    Russellville, AR
    I haven't had it aligned yet, but its suppose to give more adjustment for camber, and caster
  12. mojo
    How will caster adjustment be accomplished? Those UCA don't seem to have any adjustment nuts?
  13. bmcdaniel
    All adjustments are done on the lowers. They have front and rear eccentric bolts, same effect as the first generation Mustangs where caster and camber were set by adding shims to the front and rear UCA bolts.
  14. bmcdaniel
    When you get time please give more information about what you had to do to get the plate to fit. Doesn't look like you had to narrow it.
  15. mojo
    Will those eccentrics adjust caster & camber or camber only? If caster is set, wondering if 3-4+ degrees can be accomplished? Interested in seeing how this mod will workout..
    73curtis likes this.
