anybody use a detroit locker?
Discussion in 'Technical' started by Clintd, Dec 6, 2010.
  1. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    I'm thinking of buying this (Click here). Any major cons? I'm tired of the week as hell springs in a factory Trac-Loc. When I slam the pedal to the floor i better get totally sideways.:)
  2. darren
    Mine has a locker and it works great. Bit noisy in parking lots and right turns but to be expected. No issues city driving at all. I wouldnt replace it with a clutch type lets put it that way. My last car was a factory clutch type and this locker is no worse in wet weather. I thought the locker might be an issue with turns but it rolls around corners fine and doesnt lock on turns unless you get onto it pretty good. I think it actually works better on turns than my clutch type did with shimmed springs.
  3. Clintd
    Clintd Member
    Parlin NJ
    Thats good to hear. I pulled my factory unit apart after letting my Neises boyfriend take it one run down the track and he was half out of the grove and did a 1 legger for about 60'. It took like the first coils off of the load springs. so I cleaned up the tops of the springs and put them back in with 2 nuts underneath to shim them up. I'm going to replace this with a locker because of how crappy the design of this OEM unit is.
  4. maverick75
    Shoot a PM to Bryant, he`s our rear end guru.
  5. Bryant
    i ran a detroit in mine for a while. they suck with a stick shift. they are alot of fun with an automatic.
    sounds like your missing a part in your tracloc. there should be a metal pice that goes over the springs that will keep them from beeing rubbed on by the side gear. a tracloc can be shimmed really tight and will work really well when set up correctly.
  6. Mavaholic
    Why do you say that?? I have one in my Sprint behind a 4 speed and it is an absolute blast. Wouldn't have anything else.
  7. Clintd
    Clintd Member
    Parlin NJ
    That's what I thought, but I couldn't find a diagram with any info on the 8" to verify it. If anybody has the parts I'm missing I'll buy them to hold me off.
  8. Bryant
    the gap between the teeth in a detroit locker make for some big baning and clunking when you lift off the gas and or apply the gas. now a power trax or lock rite dont have as much of a gap between there teeth and dont behave the same way.
  9. Bryant
    i found this. i didnt find anything biger
  10. darren
    I know this is a 9" but if memory serves Bryant is talking about number 9 in the diagram.
    http://www.drivetrain.com/images/stories/product_imgs_large/ford9traclockblowup_large.jpg
  11. darren
    Ok too funny. You beat me by a few minutes.
  12. Bryant
    google image search is a great thing
  13. Clintd
    Clintd Member
    Parlin NJ
    Iv seen that image but that's for a 9" and the clutches are different. So I wasent sure if any of the parts are the same.
  14. darren
    ITs similar design though. Think your missing number 9 in the pic. thats how your springs got damaged.
  15. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I've got a Detroit locker in my 9", and it looks nothing like what's in the ad you show. Looks more like the Yukon versions at the bottom of the page...
