anybody using a 300-6 or 2.3 turbo engine
Discussion in 'New Members Forum' started by dav, Nov 12, 2013.
  1. dav
    dav Member
    wisconsin
    1970 maverick,tdi jetta,super duty
    curious if any of you guys are using the 300-6 or 2.3?
    I am on the fence for motor choices, between the 300 and a 2.3 turbo.
    the trans will be a t5 for sure. I have a complete 1988 turbo coupe lined up for $500. and no leads on a 300 (shouldn't be to hard to find one).
    any insight?
  2. Krazy Comet
    The 300 is too tall and long to fit comfortably and the turbo won't clear the passenger side shock tower without cutting... Plus the motor mount supports are unobtanium unless you can find someone in Brazil to send a set, basically must be fabbed... Also the '87-'88 Turbo Bird EFI harness is difficult to work with, the OBD test port is in the ABS/ride harness that plugs into the engine harness near the computer... Owned a dozen of the turbo Birds, had lots of experience with them(why I converted my keeper to 5.0)
  3. mercgt73
  4. Krazy Comet
    Also I forgot, you'll need a 2.3 front sump, oil pan from a Pinto Bean or Double Mistake to even be able to set it down in the hole... All the Fox chassis and Rangers use a rear sump pan...
  5. mav1970
  6. dav
    dav Member
    wisconsin
    mine is even the same color!! its meant to be!
  7. 71gold
    with...no tower braces or M C bar...:bouncy:
  8. mav1970
    And looking at it once again, I can see no reason to not have the 2 tower to firewall braces - the M/C bar might take a bit of thought and planning but is certainly not impossible :thumbs2:
  9. iraceitall
    iraceitall Member
    Was a Comet
    I would actually love to see a stout 200 build, or better yet, and this is my someday goal: Coyote swap.
  10. 71gold
    i guess the intake would prevent the pass. shock tower from collapsing...:D
  11. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    If you can find 1 get a 240 6 cyl which is not as tall as a 300,same mtr just shorter stroke.I believe it will probably fit a mav & if you are looking for longevity & reliability it is a much better choice than a 200 or the 250.
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Running a quarter mile at a time the towers will probably hold up fine, it's coming down from the wheel stands that's going to hurt them!
    Now that's funny!
  13. mav1970
    Good point :rofl2:
