Anyone done a 2.3 svo swap
Discussion in 'General Maverick/Comet' started by Mustangnut, Oct 15, 2014.
  1. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Kind of tinkering with the idea of doing a 2.3t swap in the maverick. Had 302s and a 5.0 in the car and the carb side of the deal always drives me crazy.
    I'm teetering between a 351w and a 2.3. What do you think?
  2. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    I really want to do that swap eventually. It'd be hilarious to pull up next to somebody, have them compliment your ride, and then rev up a four cylinder and blow off :D
    I don't honestly think it would be that hard, except for the oil pan.
  3. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    What's the problem with the oil pan?
    I found a comete setup in a car running with a bunch of goodies with the ecu....harness....and trans
  4. Krazy Comet
    The Fox chassis are all rear sump but I believe it's possible to use a Pinto/M-II oil pan and pickup though...
    Biggest issue I can think of is motor mounts and possibly needing shock tower clearance for turbo...
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Someone on here had a turbo coupe engine in their car before changing to a turbo 460. Can't remember their name. Why not put efi on the 5.0? Like you I got tired of carbs and went efi.
    DC12VOLT likes this.
  6. z28th1s
    Lynchburg, VA
    A turbo 2.3 with a T5 would make for a pretty fun little car!!
  7. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    What all is involved with going efi on the 5.0?
    Cost?
    Gains?
    Thanks
  8. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Well its in the works. Picking up a running driving 87 turbo coupe on Friday.
    Has a holeset turbo walboro pump and a few other goodies already.
    I know I'll have to make motor mounts and clearance the oil pan. That doesn't scare me......wiring does Lmao.
    I've gotten bored with the sbf stuff and am ready for a change. And hey if it doesn't work out I'll have a 2.3t up for sale for cheap haha
  9. Krazy Comet
    Auto or 5 speed??
    For the '87 & '88 T-Coupe the PCM wiring in intertwined with the ABS and ride control systems, radiator fan(s) controller, fuel pump, etc... Computer test plug is in the ABS/ride control harness, it and ECM harness connect together at passenger kick panel...
    Your best bet for easiest install is find a '85 or '86 harness and repin the few connectors that are different/missing... Also possible to get the harness from a 4cyl '87-'88 Stang and add the necessary circuits to it...
  10. CaptainComet
    Someone here was working on a 2.3 turbo swap and I think they were using Brazilian motor mounts because the Mavs had four cylinders available. The Pinto oil pan sounds familiar too. A search here ought to turn up someone's mostly-done project.
  11. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Sweet good to know. I wonder if Brazilian motor mounts still exist????
  12. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    There is a guy on youtube and this forum I believe with a 2.3t from a 88 tbird that used the tbird harness. Said he cut everything except vital wiring....not sure what that means lol.
  13. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Oh and its a t5
  14. Krazy Comet
    Good, the 2.3 A4LD automatic is weak & sucks majorly... Boost was limited to 8-9 psi in those just to hopefully keep it alive...
    A A4LD is about five inches longer than the T-5 and requires a special D/S & crossmember... Bolts in farther back than the AOD/T5 crossmember...
  15. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    The tc donor already has had the stock turbo replaced with a holset he351. It needs a front mount intercooler so until it gets intercooled the timing and boost have been dialed back to 8lbs anyways.
