Anyone have a wiring diagram
Discussion in 'Technical' started by Hairy W Bush, Oct 11, 2012.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    For my 72 Maverick? I was trying to figure out why my dome light doesn't come on. Well, there's a couple fuse box slots that are missing 1 set of the prongs. My dash lights don't work so it might be the same circuit. I guess I'm going to need a new fuse box so where can I get one?
    And I'm not sure of the color on this one. It's a reddish/pinkish wire and it comes down individually behind both of the door hinge post. Both sides are just cut.
    FOUND THESE: http://www.ebay.com/itm/50-Pcs-Meta...372?pt=LH_DefaultDomain_0&hash=item46081934d4
    http://www.ebay.com/itm/50-Pcs-Meta...377?pt=LH_DefaultDomain_0&hash=item5ae9e5aa91
    2 different sizes. which one do we have?
  2. Craig Selvey
    I doubt your fuse panel will need replaced. I also suspect that your fuse panel is NOT missing some of the "prongs". Some were not there from the factory.
    There are online wiring diagrams for a Ford Maverick. I don't have the link. Hopefully somebody will post it for you.
    Sounds like a blown fuse to me.
  3. Moneymaker 1
    Panama City Florida
  4. Hairy W Bush
    Hairy W Bush Member
    Georgia
    no they're definitely missing because only 1 set holds a fuse in two slots.
    and moneymaker, thanks for the link. hopefully I can find one that just says PINK.
  5. blugene
  6. doncomfort
    chillicothe oh
    Might be related to the headlight switch.
