Anyone know what this part does?
Discussion in 'General Maverick/Comet' started by CaliMaverick72, Oct 12, 2021.
  1. CaliMaverick72
    CaliMaverick72 Member
    California
    1972 4 door Maverick
    I located this unit under the dash, passenger side of my 72 Maverick 4 door. It was unplugged and when partially plugged in, the unit vibrates and buzzes. I am trying to get my interior fan switch to operate the different speeds again but came across this. Also, if anyone has a recommendation on what to check for my fan speed selector not working anymore, that would be great. It just stopped working one day a couple years ago. I replaced the red resistor on the blower housing and that didn’t fix it.
  2. kansas_grabber
    kansas_grabber Member
    Lawrence, KS
    73 Grabber
    Part number search indicates it's the buzzer for the seat belt and ignition key. It was probably intentionally unplugged. That's one of the first things I did on my '73 when I got it many years ago.
    Static likes this.
  3. CaliMaverick72
    California
    Thanks for that info. Makes sense now.
  4. mojo
    Is the fan working on any speed?
  5. CaliMaverick72
    California
    There is some air flow through the vents/defroster but does not change with speed selector switch on dash.
  6. CaliMaverick72
    California
    Also it’s very little air flow
  7. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Oooh, save that, it's rare! Mostly because everyone hated that buzzer so much one of the first things they did was find it and get rid of it. :LOL:
  8. CaliMaverick72
    California
    Haha. That’s some good advice. May be worth a lot of money some day.
  9. Acornridgeman
    Wisconsin
    If you're in a boneyard, pluck one out of a newer car that has the chime tones instead of the buzzer. They swap right in, same plug.
    TeeEl likes this.
  10. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    Most commonly, when the fan speed doesn't change, it is due to a defective resistor. These are usually a plug in module under the dash not far from the fan. They're often attached to the back of the heater box. Haven't ever replaced one in a Mav so I'm going by other cars.
  11. mojo
    I replaced my resistor a few years ago when I had similar issue as CalifMaverick. I did have hi-speed only -- fan worked on hi-speed. Replacing resistor solved my issue.
    CaliMav. replaced his resistor -- didn't solve his problem. Maybe the motor is bad?
  12. Craig Selvey
    It doesn't sound like your fan is working at all. You should be able to hear it/feel it when it is working and turned on. I bet it is the fuse.
  13. mojo
    If fuse is bad, most likely, has a short circuit or motor drawing to much current. If replacement, blows a 2nd fuse, that is where I would concentrate my research efforts.
    Craig Selvey and Krazy Comet like this.
  14. Krazy Comet
    Agreed, if resistor is bad, HIGH will still operate. High bypasses resistor, lower speeds have a voltage/current drop through resistor.
