Anyone Know Where She Is ????
Discussion in 'General Maverick/Comet' started by Tea'sGrabber, Sep 24, 2014.
  1. Tea'sGrabber
    Tea'sGrabber Member
    Washington
    1971 Maverick Grabber
    Sold her back in 08 ish........
  2. Paul Masson
    1971 Grabber
  3. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    WOW, you ran 11.40 on a factory head 302? I notice the 12.75:1 and mechanical roller, may I ask how did you get that compression and what the lift/duration was on that cam? This is NOT a doubting smart ass, I believe you just want to know what it requires to do that, also what gears were you running and what trans/stall? Thanks
  4. SamsDad
    SamsDad Member
    Little Rock, Ar
    Dang nice car BTW
  5. Tea'sGrabber
    Tea'sGrabber Member
    Washington
    Let me see if I can remember the specs. Block was a seriously decked Mexican. Speed Pro Soap Bar forged pistons. Carrilo rods. Cast crank. Heads were small chambered 67 or 68 GT's. Big valves.... Comp did the cam @ .50 it was 260-270 ish...700 lift. JPT in Michigan did the C-4 with 5500 converter. Currie 9" with 4:11's.
  6. z28th1s
    Lynchburg, VA
    Definitely a nice looking car that ran VERY well!! Good luck with your search!
  7. SamsDad
    SamsDad Member
    Little Rock, Ar
    Ohhhhh, when you said OEM heads I was thinking something else entirely, and decking helps explain that compression with pistons, I take it your missing her? can't blame you
  8. Craig Selvey
    Wasn't that car on eBay recently?
  9. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
  10. Red1972Grabber
    Northern California
  11. Red1972Grabber
    Northern California
  12. mavgrab302
    Grabbergirl719 had her own car, it looked like jimmy's but was a different car...
  13. Tea'sGrabber
    Tea'sGrabber Member
    Washington
    Thanks guys...I e-mailed Jimmy. I reluctantly sold the car to pursue another hobby. I no longer live in Washinton state. My wife and I moved to Nashville and my other hobby has been fun. I gave up cars for guitars and now I have the high octane itch again.
