Anyone running the 96+ explorer rearend uncut?
Discussion in 'Technical' started by flynbrd, Sep 29, 2010.
  1. flynbrd
    flynbrd Member
    I read before that if you install the 96+ explorer rear offcenter that the driveline will hit the tranmission tunnel. How much clearance will I need if I'm running the late 80s and early 90s mustang driveline shortened to fit? I have 05+ gt mustang rims on the car however with the 1.5 inch spacers they are still close to the leaf spring. I'm hoping the stock length explorer will give the little extra I need to center the wheels. If not I can run shims.
  2. Dave B
    There is someone here that did it uncut, I have one and measured it, I won't use it uncut, it's way off for my liking.
  3. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    i looked at doing this as well, didn't like what i came up with in measurments
  4. dtb147
    dtb147 Member
    Arbutus, MD
    I have one in the garage that I'm debating what to do with. The perches are about 3" too wide, (1.5" per side), so at the very least you'll need to relocate them. I spoke with someone who had done this and it sounded like a BFH fixed the tunnel clearance. Personally I think I'm going to buy a new short side axle and cut the long side to match. It's about 2 7/8" difference which puts it about the same length as the Maverick rear, puts the perches where they need to be, and centers the chunk. Still up in the air on that though.
  5. diddie
    diddie Member
    indiana
    With a little work sounds like a good idea to me
  6. Dave B
    Looks like a simple thing to do, I've found a few write ups out there on the net.
  7. Mavaholic
  8. dtb147
    dtb147 Member
    Arbutus, MD
    Does anyone know if the Addco rear sway bar will fit this rear if you use bigger U-bolts? Perhaps weld on some brackets to mount the bar with?
  9. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Did you price it out with Vince over at Fearless Gear?
  10. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    It never occurred to me that by shortening the long side you're off the hook for moving the spring perches. That puts this a little closer to doable.
    So after that it's just a matter of using the right U-bolts and spring plates? How 'bout the driveshaft? Anything need to be done there?
  11. dtb147
    dtb147 Member
    Arbutus, MD
    The 8.8 has a round plate that the driveshaft bolts to. Perhaps you can get the mount and u-joint off a newer style shaft and have it put on your existing shaft... lenth may be different though.
  12. dtb147
    dtb147 Member
    Arbutus, MD
    To answer the second half of your question, the Explorer rear is the right length for you to run without spacers.
  13. maverick75
    Whats the length? If the mavericks is 56.5". Ive been thinking of doing this also since i plan to run cobra R wheels. So if its 59.5" or 60" it would be perfect for my application :)
  14. flynbrd
    flynbrd Member
    yea cost was about 450, included narrowing (I supplied the axle and its only one side thats getting narrowed) grinding off all the brackets, installing perches, and going through the posi (making sure everything was in good shape) plus paint. I would narrow it but I would need to change my rims for the offset. As it sits right now my rims work best an axle thats 60"s wide. In the next few weeks I plan pulling the 8.0 and mocking up the 8.8. The first test run with driveline indicates a few whacks of the hammer should take care of my clearance issues. I think the dent will be concealed under the backseat. (at least I'm hoping)
  15. maverick75
    Okay so i google it. And the explorer is 59.75" and the pinion is 2 3/16" to the right. So if ours is centered that means we would need 2.25-2.5" of clearance if I measure it to the stock driveshaft? Im going to go measure it right now.
