Anyone using the "Try Y" headers?
Discussion in 'Technical' started by BadBrad73, Nov 3, 2006.
  1. BadBrad73
    BadBrad73 Member
    Rome, GA
    1973 Maverick
    Anyone using the "Tri Y" headers?
    They look pretty compact. Anyone know how well they fit the Mave/Comet chasis?
    brad
  2. PaulS
    They were designed for the 64 1/2 - 66 Mustangs so they may be a bit high at the collector flange. You might be able to live with it. I am going to try them in my 66 Mustang with a 351 Windsor witch will raise the header about an inch above stock. They buld a lot of torque without sacrificing much in the upper RPM range to about 6500. Most of the ones they are making now are using bigger primary tube size. I figured if they were good enough for a 305 HP 289 they would work for 300 HP 302. My 351 will run just under 1 HP per cubic inch so they should be fine on it.
