Anyone using this T5 hydraulic setup?
Discussion in 'Technical' started by Acornridgeman, Oct 26, 2012.
  1. Acornridgeman
    Wisconsin
    Anyone using this setup for their T5? If so, did you get the 65-66 Mustang unit or the 67-73 Mustang unit? Any problems adapting to the Maverick?
  2. Streamliner
    Streamliner Member
    First time i've seen it....I wonder why the pushrod {pullrod?} is on an angle
  3. mercgt73
    That looks pretty neat. Is it a Wilwood product?
    It would seem as the L shaped bracket rotates CCW, it would straighten out the piston pushrod along with the pedal pushrod.
  4. Acornridgeman
    Wisconsin
    From what I'm reading about it, it allows use of the existing clutch rod hole through the firewall. This makes install easier and puts the master in a better spot than higher up. Also, having the lever action on the master greatly reduces pedal effort.
  5. Acornridgeman
    Wisconsin
  6. Dave B
    OOoooooOooh I like!!! I have the Wilwood stuff, but it doesn't look like that.
  7. John Holden
    John Holden Member
    NJ
    Thats a pretty nice setup. I think I'm eventually going to do a hydraulic clutch. I'll keep this in mind. I'm also curious which kit is best with a maverick.
  8. tody
    tody Member
    cologne, germany
  9. Dave B
  10. Acornridgeman
    Wisconsin
    Wonder why the Maverick one is $40 more? Sure would like to know what is different from the Mustang or all the other kits.
    :hmmm:
  11. Dave B
    They know Maverick guys are willing to spend more money...:rofl2:
  12. John Holden
    John Holden Member
    NJ
    Because mavericks are better!
  13. mercgt73
    Eric, did you end up buying this kit from Mustang Depot / Modern Driveline? Just curious...
  14. Acornridgeman
    Wisconsin
    Not yet but I'm leaning towards this set up. Due to a couple set backs, I won't be up to the clutch work until spring. I will update this thread when I get it.
    :thumbs2:
  15. Mavfreak
    Mavfreak Member
    Ca and Ks
    69.5 & 72 maverick
    that is a smoking deal I bought a McLeod kit (willwood cylinder) 600.00 I think I had one shop do some work and they charged me 750 (install) the pedal was too hard so another shop charged me 750.00 to ease the pedal. well it worked. I paid them 750.00 to bend the rod and mount it 1/2 inch higher. needless to say I will be purchasing the modern driveline kit and swapping it out myself.
    I will have just under 2500.00 (including clutch) in my car solely to have a stick car... (this must explain why I have spent more money building my car than most people) I must be some kinda special retard, but hey... I am ok with it.
