AOD Decoder?
Discussion in 'Transmissions' started by Jsarnold, Nov 28, 2011.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I've been searching for an AOD tag decoder but haven't found one. Found answers to questions on specific transmission IDs but not a general decoder or table.
    I picked up an AOD yesterday with this tag.
    PKB AE1
    068112 B27
    E9TP PB
    From the specific decode examples, I think this is out of either an '89 or '90 F150.
    Can anyone confirm that?
    Is this a good choice to swap into the the Maverick? Might have a longer tail shaft and housing?
    Seller says it has about 80K on it, has been inspected and resealed and works well. If all that is true, think it was a good deal. Came with new (stock) TC, shifter and cable, TV cable, dip stick, cross member, block plate and drive shaft for $250. If its just a rebuildable core I don't think its a bad deal.
  2. Dave B
    Does it have the hole for the speedo gear?
    I'll look for the info I have saved.
  3. igoback70
    igoback70 Member
    IN
    70 Maverick
    Yes that transmission was offerd in a 1989 F-150, i work for a Ford Dealership and checked that part #, it is a 89 but it was offerd in many trucks and vans.
  4. Jsarnold
    '72 Sprint
    Yes it does. I know 'cause fluid poured out the hole onto my garage floor.
  5. Jsarnold
    '72 Sprint
    Great. Thanks. :Handshake The salvage yard wrote "F150" in marker on the trans so guess that's it.
  6. igoback70
    igoback70 Member
    IN
    70 Maverick
    Not a problem, i saw your thread while i was on lunch and went and had someone run the # for me, as long as the part is 85 up i can usually find out, anything older than that requires a micro-phish, i dont think our parts department has one of those. :)
