AOD is it worth it
Discussion in 'Transmissions' started by bartikus, Apr 19, 2012.
  1. bartikus
    bartikus Member
    salt lake city, ut
    so about a week ago my transmission made a strange noise and then went away so i started thinking about what i would do if it went out on me. i would either rebuild the stock C4 or possibly swap in an AOD. so any one out there that has done this swap what does it take? would you recomend it for the overdrive gear? let me know i'm not in any hurry because my trans seems to still be shifting fine and the fluid looks good just want to be able to wiegh in my options if the time ever comes.
  2. Bryant
    i personally feel going to an overdrive is well worth it.
    you wont recover what you spend in gas milage so dont do it just to try to save on gas cost.
    you will want to change the rear gear ratio to take advantage of having the overdrive. if you dont the car will be a slug in over drive. chances are the rpms will be too low on the freeway to allow the engine to run efficiently.
    if your building for performance then its worth doing. you will want to get an aod that is built for performance. a stock aod just doesnt cut it.
    you can run a higher stall also. the aod has a lock up converter feature. this locks the converter shell to the input of the trans in 3 and 4 gear. this gets rid of the converter slippage factor in those gears and yet will allow your motor to be more in its power band when taking off.
  3. 71gold
    I've sold right at 60 of these AOD crossmembers to people here on the board...:yup:
    100_0835crossmember_thumb.jpg MG] ​
  4. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Hang on thats a Tremec crossmember...:biglaugh:
    Yeah with franks crossmember(he does awesome work by the way and it is worth it to get one of those if you are going to do the swap) and a Lokar cable set it is pretty easy to setup. Were you planning on going with a floor mount shifter or use the column still?
  5. 71gold
    thanks...:Handshake
    that's also a...C-4...crossmember I made for my car...all the pieces are the same, just welded together differently...:thumbs2:
    ...:D...
  6. WesCoaster71
    WesCoaster71 Member
    california
    1971 ford maverick A.O.D trans 302 5.0 cu
    would that crossmember work for dual exhaust?:chirp:
  7. markso125
    markso125 Member
    Lewiston Ut
    :yup: YES it works just fine with a dual exhaust
  8. WesCoaster71
    WesCoaster71 Member
    california
    Wat about a 71 mav with aod sorry if i sound like a dummy but i just wanna make sure that i can find the right part. I was also trying to find frame mouts for a 302 so i can drop my engine in my mav..... Couldnt find the exact ones sooo i kept searchin on these fourms and found that 67-70 mustang frame mounts should match up fine with the insoleators but i wont find out till i get the part in a few days anyone know for a fact?
  9. WesCoaster71
    WesCoaster71 Member
    california
    And 71 gold knows were to get these?
  10. 71gold
    I have a set of these...also the throttle cable w/pedal and belly bar...shoot me a PM if interested...:Handshake
    sorry about...:jack:... the thread...:tiphat:
  11. WesCoaster71
    WesCoaster71 Member
    california
    I also got a set of hooker headers that drop pretty low and was wonering if anyone knows if there will or will not be any clearance issues with installation?:anyone:
  12. markso125
    markso125 Member
    Lewiston Ut
    The biggest clearance issues you will have with those headers involve speed bumps:rofl2:
    You will have to probably massage one or two of the tubes getting them around the shock towers but they fit around the transmission just fine.
  13. WesCoaster71
    WesCoaster71 Member
    california
    hey guys im getting ready to drop my motor in and i just wanna double check on some things.....:dancing:
    1.what are the torque specs. for the flywheel/flexplate bolts?
    2.how many quarts should go into my tranny if its almost completely empty. i put tranny fluid in my torque converter (like a quart) before assembly of engine and tranny and my tranny was full before it leaked out the rear seal from a previous attempt. the first attempt was a fail becauce the guy i got my engine from failed to mention i might need a new oil pan:hmmm:. the engine originally came out of a 84 lincon town car. the oil pan(from the lincon) was hitting on the center link for the steering. i got the new pan oil pump and pick up on order for (71 maverick 302 w/ a.o.d) . hopefully some one can help me out:huh:
