AOD not shifting?!
Discussion in 'Transmissions' started by 71_Maverick, Jun 7, 2007.
  1. 71_Maverick
    71_Maverick Member
    michigan
    i have an AOD that will only shift between first and second and the other gears it would shift into. is this from a lack of fluid or it the transmission dead??
  2. maverick75
    my AODE was doing this, it was because the TV cable had come loose.
    Good luck
  3. PaulS
    Check your fluid level first, it is the easiest thing to do.
    Next check that the throttle valve linkage is connected then adjust it to be sure you are getting the correct pressure. Too much or too little will destroy your transmission in no time at all.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    You dont have an E if it has a tv cable.
  5. PaulS
    I need new glasses too! I completely missed the "E" in that AODE.
    That means it could be the TPS, wiring, speed sensor or the EEC itself.
    Is it throwing codes?
    When you put it in "drive" it starts in low - goes to second and then stays in second? If it won't shift to third or OD you might have a bad direct clutch.
  6. maverick75
    yeah mine wouldn't go into 3 or OD...but i just unhooked the battery for 30 minutes(i heard that's how you reset the codes) and it fixed it its been 1,500 miles and it running normal.
  7. maverick75
    thats shows how much i know about trannies:D i was referring to this cable.
  8. 71_Maverick
    71_Maverick Member
    michigan
    i filled the trans up, and i belive i have the tv cable adjusted in a ball park range because i cant get the guage or anything so if someone knows how to do it by hand that would behelpfull. its stuck in second and wont shiftout i have reverse and first no problem.
    i talked to a tranny guy and he said it should shift through the gears without the cable but really fast.
  9. greasemonkey
    Sedalia,MO
    Be warned it could smoke that thing in a hurry if you dissconnect the cable. How does the fluid look?
  10. 71_Maverick
    71_Maverick Member
    michigan
    the fluid was clean and the pan was also. sould it be a valve sticking or the filter??
  11. PaulS
    The AOD should shift from 2nd to third after forty-five mph and befor fifty-five with the cable adjusted properly.
    There are several methods to adjust the cable without a gauge. If you can't find it in your book then contact me off line (email) and I can give you one way.
  12. PaulS
    If the direct clutch is burned up you won't get third or fourth gear.
    If it only happened once in a while it might be fixable but if it always works this way then the direct clutch is gone. Time for a rebuild and the proper setting on the TV cable (if so equipped).
  13. PaulS
    How goes the battle?
    Did you adjust the TV cable?
    Have you decided to pull it out or take it to a shop?
    What ever you do, after you get it back in be sure to install a big cooler. It will help the tranny last a lot longer than it would otherwise.
