aod stuk in low gear
Discussion in 'Technical' started by gwil81, May 4, 2008.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    i put the aod in an it just wont change gears help please
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    is it an aod or c4? unless you swaped in there, its a c4
  3. 71gold
    PM sent...:Handshake
    ...Frank...
  4. Dave B
    I hope you haven't driven it much.
  5. PaulS
    gwill,
    If it is not shifting at all it is probably a problem with the TV cable.
    They have to be adjusted so that there is no slack in the cable and it reaches full pressure at full throttle. The only sure way to adjust the TV cable is to use a pressure gauge in the TV port and adjust the idle pressure to approximately 5psi and full throttle pressure at 80psi. If you drive it with the cable out of adjustment you can destroy the AOD.
