aod tranny
Discussion in 'Parts Interchange' started by Yellow72Mavrick, Feb 3, 2006.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    will a aod tranny fit our mavericks without cutting. will it bolt up to a 351c. imput please...Jim:huh:
  2. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Sorry I can't help with this one. Just popped in to say hello.
  3. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    Hello, From what I understand is it will bolt up with no cutting, but you will have to use a BFH to pound the trans tunnel and where it meets the firewall and no headers will clear the bigger bell housing.
    Jim
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    It will bolt to a Cleveland.
    That is my contribution... I don't know about the Mav part.
    I also would think that headers might fit easier with a Cleveland.
    The 351 is wider, and the pipes point downward, so all the clearance issues should be done with by the time the pipes are near the bell.
    Dave
    Edit: Make sure u use a 28 oz flexplate!
  5. Yellow72Mavrick
    Memphis, Tenn.
    thanks for the imput, gives me something to look at.
  6. tomeriker
    tomeriker Member
    Indiana
    1972 maverick project..
    If you could find the right flywheel to match the engine and trans balance. I don't know of any that do.. would probably have to be aftermarket custom made..But as far as it fitting in the tunnel. I have an FMX in my 72 that is larger than my AOD and I did no cutting or hammering.. just made an adjustment to the crossmember. I did make my own motor mounts so I might be forward a little.
  7. Yellow72Mavrick
    Memphis, Tenn.
    Tomeriker thank for the info, you other guys too, lol...Jim
  8. 74merc
    74merc computer nerd
    1974 Comet
    With a 302, eaders will pass the bellhousing just fine, looks like 6901s would be a perfect fit. Hooker super comps are really close to the pan, I had to ding a spot on my pan to make it all fit.
    28oz 164tooth flywheel are not hard to come by, any large bellhousing C4 should have one, I think you're looking for Tbirds and trucks as donors. Mine came off an unknown 77-78 302, I think a truck engine.
    With manifolds, I modified my kickdown and shifter linkage to work, with headers, I'm running a custom cable shifter and a Lokar TV cable. The tranny crossmember takes a bit to get working, I recommend buying a Mustang AOD conversion crossmember or making your own.
    In my 74, no hammer was required until I got the Hooker Super Comps.
    When I first replied, I missed the 351 part. Should still be the same flywheel, I do believe.
  9. Comet155
    Comet155 Member
  10. Comet155
    Comet155 Member
  11. Comet155
    Comet155 Member
  12. 74merc
    1974 Comet
    the Mustang conversion crossmember is a good start. The link to Mustangsandmore was what I referenced when I did my swap. Most of the info in that write up is pretty close to our swap, and it sounds a lot more complicated there.
  13. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
  14. chupafuego
    chupafuego PhxCOMET
    Phoenix
    1971 comet
    I had my engine rebuilt and balanced to the flywheel (71) comet. Do the torque converter bolts match up. And how much hammering? The best aftermarket crosmember match?
